Question about HP P2055DN LaserJet Monochrome Printer
Can't find paper jam in output bin - HP P2055DN LaserJet Monochrome Printer
    New Friend:
Jamn output bin". When I open the door, and clear the jammed paper, it still show the problem.
Posted on Mar 09, 2014
SOURCE:
  • 6 Answers
SOURCE: jam in bin
this is a common fault. look where the paper was jammed, you may need a torch. There is a black or white sensor there that has been dislodged. Once clipped back into place it will then report to the printer that the paper path is clear and no longer a jam.
Posted on Oct 05, 2009
  • 24 Answers
SOURCE: how to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
Posted on Dec 23, 2008
leroyal
  • 2120 Answers
SOURCE: jam in output bin
Try taking all of the paper out of the paper tray and try to pull it from the front of the printer.
Posted on Jan 11, 2009
  • 224 Answers
SOURCE: Getting the error on my HP 4345mfp - TOP OUTPUT
my experience says jamming in duplex area using card stock. this may occur if default is duplexing. set default to single side and / or try same job using plain a4 80gm2
Posted on Mar 31, 2010
  • 37 Answers
SOURCE: Can't find the paper that
The output bin sensor check the quantity of printed paper that remain in the upper part of the printer. When the paper is too much, the sensor report a paper jam.
Check the lever of the sensor in output bin if it's working properly
Posted on Jun 15, 2011
REMOVE ALL PAPER FROM BIN ,OUT PUT BIN IS FULL Hi
Does not sound like a paper jam problem but a sensor problem sensor acurator is broken or out of place or the sensor is bad worse case the control that the sensors reports to is bad. Check you Output Bin Sensor acurator.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 06, 2013 | Minolta QMS PagePro 9100 Laser Printer
Can't find the paper that is jammed in the printer (laserjet 2600n) its says its in the output bin
Jun 15, 2011 | HP Color LaserJet 2600n Printer
Paper feeds about half way and then stops. All of the indicator lights come on.
If you get a paper jam, the Paper Jam indicator light promptsyou to clear the paper path. If the paper has just started to feed from thepaper feeder when the jam occurs, pull the paper straight up out of the paper feeder. Open and close the printer cover toresume printing. If the paper jam occurs inside the printer, remove the paper from the output bin. Turn the printeroff, then on. If this doesn't clear the jam, open the printer cover.Remove the print cartridge and cover it.For additional assistance, please contactLexmark Technical Support
Apr 11, 2011 | Lexmark Optra E312L Laser Printer
Display reads - " jam in output bin " jam was
look at the output area, make sure that the paper lever is working. Sometimes they come loose after a jam.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 21, 2010 | HP Laserjet CM 1312NFI Color Printer
Paper Jam at HP LaserJet P2055d
There is output sensor where the papers come out, make sure its lowered down, be VERY CAREFUL not to break it.
Jun 11, 2010 | HP LaserJet P2055d Printer
My printer says there is a jam in the output bin but there is no visable jam. HP color laserjet 2600n
Just try the steps
Jam in output bin - fuser area Error messageJam in output binalternates withOpen door and clear jam DescriptionA paper jam has occurred in the output bin near the fuser area. Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.
Jam in output bin - duplex area Error messageJam in output binalternates withOpen door and clear jam DescriptionPaper jam in duplex reversing area Action
  1. Clear the jam.
  2. Press the c00381085.jpg (SELECT) button on the control panel.Please Rate my response!!!Thanks, SF
Jan 28, 2010 | HP Color LaserJet 2600n Printer
Getting the error on my HP 4345mfp - TOP OUTPUT BIN, PAPER LATE JAM. 5017-Oct-2009 02:02 PM18209913.09.0048.081.2TOP OUTPUT BIN, PAPER LATE JAM 4917-Oct-2009 02:00 PM18209613.09.0048.081.2TOP OUTPUT BIN,...
Oct 20, 2009 | HP LaserJet M4345 MultiFunction Printer
How to clear paper jam in output bin
Dec 21, 2008 | HP Color LaserJet 2600n Printer
Jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Jul 08, 2008 | HP Color LaserJet 2600n Printer
Paper Jam errror
Error message
Jam in output bin
alternates with
Description
Action
  1. Clear the jam.
  2. Press the (SELECT) button on the control panel.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Error message
Jam in output bin
alternates with
Description
Action
  1. Clear the jam.
Goodluck..
May 14, 2008 | HP Color LaserJet 2600n Printer
HP P2055DN LaserJet Monochrome Printer Logo
2,149 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
