Question about Golf
Troubleshooting charging system on a gas club car
CCan charge batteries with a charger but cart will not charge battery
  • 101 Answers
Measure your battery voltage. Then measure your battery while cart engine is running. If you get 2 or 3 volts higher while engine running than when it's not, your charging system is ok. Lets say your voltmeter measures about the same voltage either way. Remove the small yellow wire on the starter/ generator and insulate. Place a jumper between the post that the yellow wire was on and the negative post of the battery. Now measure the battery while the engine is running. If you now measure higher voltage then your voltage regulator is bad, if you don't measure higher voltage then your starter/gen is bad.
Posted on Sep 19, 2017
SOURCE:
SOURCE: Charging problem.. Wont charge battery
The instructions for installing a new alternator usually read to fully charge the battery (12.3 - 12.8 volt range). Otherwise, the alternator will be damaged when it initializes. I have seen some extreme damage result from installing a new alternator with a low-charge battery. The torque required to turn an alternator when damaged in this scenario is unbelieveable!
Posted on May 02, 2009
samson-1
  • 153 Answers
SOURCE: Can I charge Intrepid battery from the jump start posts?
You should be able to do this with no problem.
Posted on Nov 08, 2008
DAD5bbbbg
  • 111 Answers
SOURCE: fault light on vector battery charger flashing
Make sure that you have the pos and neg on right.
Posted on Mar 16, 2009
  • 166 Answers
SOURCE: Electric Golf cart only shutters and inches forward
so many possibilities...
does it roll fairly freely? (checking to see if the brakes or rearend seized up)
Are there any "bad" sounds like things grinding? (Connection between Motor and rearend, axle splines...)
If all that is solid, it is likely in the controller.... (it takes a solid charge right... No bad batteries in there or loose connection? might want to check all the battery connections to make sure none are burnt...)
1997.. does it have the electonic speed control by that year? the other possibilty is that the accelerator is not working corectly. they used a resistor system on old ones that has contactors that would get worn out.... Newer ones control a potentiometer(sp) that controlled the speed.
Only a few real components to check, but if you are not mechanically and electically inclined, could be tough to isolate.
peace,
Posted on Mar 07, 2010
  • 82 Answers
SOURCE: I have 2004 EZgo electric golf cart. When I plug
Check for a tripped circuit breaker. usally at inline with the positive cale of the battery
Posted on Mar 25, 2010
I have a 2010 yamaha golf cart,has brand new batteries,and the batteries drain by nine holes,is it the voltage regulator? or something else
Make sure the batteries are fully charged. if your cart has it's own charger it may not fully charge. I would purchase a portable one and make sure they fully charge then you would know whether the cart charger is working.
Nov 05, 2017 | Golf
With new batteries in a EZGO golf cart, when you plug in the charger when the batteries are showing half charge, the charger runs for about 15 seconds, shuts off for 2 seconds, and then back on.
How old is this unit? What is the model number? The newer carts have an smart charger that will tell what is wrong with a flashing code on the charging light.
Oct 23, 2017 | The Computers & Internet
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Charger just workrd at my neighbors, doesn't even make a sound whwn i plug it into my cart. why does it not take a charge?
Measure your total battery voltage. That is measured across the main positive cable and the main negative cable. If you have a 48 volt golf cart and an automatic charger, any pack voltage under 42 volts will not turn the charger on. Your only recourse then would be to charge one battery at a time until you get 42 or higher.
Sep 07, 2015 | Golf
Why does my golf cart battery charger turn off after 6 seconds when battery is partially discharged?
I have seen a charger turn off like that when there is one or more bad batteries. Try a load test on each battery to see if one is bad.
You can do this with a voltmeter. Connect the voltmeter to one battery and make the cart start to move and watch the meter.
If the voltage drops a lot then it could be defective.
Aug 30, 2015 | Golf
Gulf cart battery well not hold a charge
sounds like battery is shot or bad charger.replace
Mar 10, 2015 | Golf
I bought a 2010 zone electric cart and I do not think the battery charger is working. It will show fully charged and will not last but about 20 minutes please any advise
First of all take your battery to a place that sells batteries and have it checked. Sounds like your battery is only partially charging but the charger will show fully charged as it won't charge any more. Battery could be bad.
Dec 26, 2014 | Golf
My 2000 Yamaha golf cart has 6-4cell 8 volt batteries. I did not leave the cart plugged in during the winter months. When I attempted to charge yesterday, the charger lights sequenced but stayed on...
Yes to both questions. the charger must sense 41.5 volts to activate the relay inside the charger. Being a repair shop, I have a charger that is rigged to charge even DEAD batteries. I do not recommend this for the novice. A charger set on 12 volts will bring the batteries back up to 8.2-8.6 volts. A cheap trickle charger may not put out enough to charge a battery of this size. Remember that they are used to MAINTAIN a charge. Connect the Voltmeter and watch for voltage rise. If it rises to 8.1 or above, it is charging. Trojan battery company recommends charging at least once a month.
Apr 06, 2010 | 2000 Ford Focus
Can I leave my 2004 ezgo golf cart charger plugged into the golf cart and wall all the time when golf cart not in use?
never leave charging all the time you want to charge it every 6 hrs of running time to let your batterys cycle down. it would be the same if you charge your cell phone everytime you make a call if you cant keep track of it get a state of charge its a volt metter like a gas gauge for the batterys if you do it my way you will get more run time and your batterys will last around 10 yrs if keep doing it your way them about a couple yrs on them
Jul 21, 2009 | Electronics - Others
Golf Logo
6,258 people viewed this question
Top Golf Experts
FastHarley
FastHarley
ray gallant
ray gallant
Kardoc
Are you a Golf Expert? Answer questions, earn points and help others
