MSI MS-6378 Motherboard Logo
Posted on Jan 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to & where to connect Power led + - /power sw/reset sw/HDD led
I'm using ms-6378 Motherboard on another computer & don't know where and how to connect these little jacks
Anonymous
Level 3:
  • Master 807 Answers
  • Posted on Jan 26, 2012
Anonymous
Master
Level 3:
Answers
807
Questions
Helped
232136
Points
2344
Get the user manual here: User Guide
Chapter 2 Page 17.
The plugs just fit on to little pins in the bottom corner of the board.
If you connect them and hard drive indicator light on the front of the case does not come on then you need to swap the 2 connectors around.
It's an led which has to be connected the correct way to work.
Same goes for the power led on the front of the case.
2 Related Answers
A
Anonymous
  • Posted on Mar 04, 2008
SOURCE: MS-6378 ver 2 Motherboard fitted to my Time Computer
I too need the manual and drivers for this board.
Unfortunately the link posted by Aceltix leads to the file E9266v1.0 which is the manual for the K2 - 102 (MS9266) 1U rackmount server.
Perhaps the poster could check his link and oblige by posting the correct one if it is available to him.
Thomas F. Schneider
  • 2715 Answers
  • Posted on Feb 18, 2009
SOURCE: hdd led,power sw led don't know where toplug in
Link to your manual, drivers and BIOS :
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-6378&table=download
2helpful
2answers
Front panel connections
I don't find the Front Panel header pinout online, nor do I have an MSI MS-5191 in the shop.
I would suggest using one the LED lights with two wires.
(3-wire is a dual color LED)
There are two rows of pins. Usually the Power On switch, Power On LED, and Speaker; are on the same row.
HarDDrive activity LED, and Reset Switch are on the opposite row.
Speaker has 4-pins designated for it. All the others use 2-pins.
(Unless the PWR ON LED is a dual color jobbie)
Touch two pins next to each other, in the same row; with the 2-wire LED.
Start with finding the Power On switch first.
Usually the top row 1st two pins are Power On LED (Light)
Next in line are the 2 pins for the Power On switch.
Bottom row 1st two pins are usually HarDDrive activity LED (light)
Next 2-pins are usually Reset switch.
May not apply to a motherboard old enough to use a Socket 7 processor socket.
There may be 18 to 20-pins.
Bear in mind that many are not used, and probably 4 are for an internal speaker, for hearing BIOS Beep Codes.
May be two separate Front Panel headers.
Once you find the two contact pins in the Front Panel header, for the Power On switch; I would put the Power On switch wires on.
The small pin connector on the wire/s, will keep you from accidentally touching these two pins again, when the computer is on.
Now you have the two pins for the Power On switch, and the computer is running; then keep touching 2-pins at a time with the LED. (Light Emitting Diode)
LED stays on? You have the Power On LED (Light) pins.
LED blinks? HarDDrive activity LED (light) pins.
Computer restarts? Reset switch pins.
Look for abbreviations near the pins in the Front panel header.
PWR, Pwr, Pwr On, Sw, and SW; are just some of the abbreviations for the Power On switch.
HDD LED, and HDD are two for the HarDDrive activity LED. (Light)
(If it states HDD SW it is the Power On switch. Weird old way of marking)
RST, Reset, and RSW, are for the Reset Switch.
(Reset Button)
If you see 4 pins marked with a bracket ( [ -> Turn so it's horizontal), these are for the internal speaker.
Type MSI front panel connector in your search bar, and look at -> images. See if you can find an image of your MSI Front Panel header pinout.
You can bet MSI carried out that Front Panel header pinout, on other MSI motherboards, besides the MS-5191.
The MSI MS-5191 may have been a motherboard made by MSI, especially for a pre-built computer manufacturer, and not listed on their website as an OEM motherboard.
(Original Equipment Manufacturer)
Won't have the Front Panel header pinout, listed on MSI's support website. (Doesn't)
But you can bet there IS an OEM motherboard made by MSI, that the Front Panel header DOES match.
May be different expansion slots, or motherboard chipset, or whatever; but the same Front Panel header pinout.
Regards,
joecoolvette
1helpful
I dont know how to fix the Front Panel Audio Connector. And I dont understand what is ATX power switches. I'll tell you what wire i have: H.D.D. LED, POWER LED +, POWER LED -, RESET SW and POWER SW....
Hi!
You have to make make the four Front Panel Connection as shown below: -
(IDE LED is the same as HDD LED and Ground means negative '-')
Hope it helps! Good Luck!
Thanks for using Fixya!
CreativeTECH
1helpful
I have asrock agp8x p4i65g and don`t know how connect fron power/reset buttons and fron lights. There`re 5 lines power sw, reset sw, H.D.D. led and 2 ampty
yea there are 5 lines one is power switch other is reset the power led then hdd led then in older motherboard there is provision for speaker The power switch is in the front pannel of the motherboard if you have multitester the power which will indicate 5v the power switch is to be conected to the 5v and the ground normally the front pannels details will be given in the motherboard
2helpful
Reset sw, power sw, and hdd led where do i put them on the motherboard
hello, your front panel connectors like reset sw, power sw, hdd led, you can search easily. a use of screw driver touch all front panel connectors, if any response of connectors connect it.
2answers
Want to connect my mercury PVM7 PRO MB
what type of motherboard do have? It sud be on right hand-side you will find some pins. USE MEGNIFYING GLASS THERE BE WRITTEN IN SMALL PRINT connect power LED, HDD LED, RESET SW AND POWER SW
1helpful
2answers
here it is your manual man
http://asia.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=283
msi site your board/the manual..youll have there at the beginning the diagram of wires and pins..
I have a MSI too..great boards man..great boards..
fixya:)
bye
Top MSI Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
