Question about Sony VAIO PCV-RX462DS PC Desktop
My cd rom drive doesn't work
Hi, I have an older sony vaio, about 4 1/2 years old. All of a sudden the cd rom drive won't work at all. Everything else works ok though.
  • 5 more comments
  • Laura Smith Jun 07, 2006
    Do you mean that the cd drive needs to be replaced? thanks.
  • Laura Smith Jun 10, 2006
    Yes, I probably should just get a new machine. Thanks.
  • AMSW Nov 24, 2007
    my cd drive doesnt even open some1 plz help me
  • Anonymous Mar 07, 2008
    When I put a cd , it won't read it
  • Anonymous Jul 30, 2008
    none
  • tico100teco Apr 24, 2009
    my cd player sounding weird yesterday comin in and out crazy noises i took the cd player out and it wouldin turn on no more so i checked the fuse behind the radio and the one under dash they both ok my radio on the back was very hot is it burn?
  • robin william
    robin william Jan 10, 2017
    Hi Fixya
    A expert can help you resolve that issue over the phone in a minute or two.
    best thing about this new service is you never placed on hold and get to talk to real repairmen in the US.
    the service is completely free and covers almost anything you can think of Computers printers and all software issue by calling 1-(844)-465-4646
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 181 Answers
Throwing money at "lens cleaning" would be unlikely to correct such a problem since misreads do not disable the drive either for read or for write/burn. Such cleaning typically serves little or no utility or benefit since no head contact with disc occurs with optical storage devices such as cd/dvd/bd etc. Sometimes, I have closed the door not realizing the disc was not pressed down correctly and fully onto the spindle. That error will give the impression of an absent (dead) drive because the data seek will not work with a non-spinning disc. If you were to "clean" the drive lens or whatever, you might conclude that the cleaner worked because, by mere happenstance, you properly seated a disc that had been off-spindle before. Not been there; not done that; but have "floated" a cd.
Posted on Oct 29, 2014
  • 215 Answers
I'd reckon at 4.5 years you've had an extremely good run from your CDROM. You could always try a lens cleaner which you can get from any good music shop but judging by your unit's age you deserve a newer and faster Unit. Maybe a CD burner or even a DVD burner. They are much cheaper these days. My first single speed CDROM cost me $999.00 I can now buy a 52 speed CD Burner for $49.00 BMW
Posted on Jun 07, 2006
    Novelist:
  • 136 Answers
Hi there I do understand the problem First i'd like you to check whether the burner is getting recognized or not-Insert bootable CD and tried booting the computer through bootable disk. If that works then we can confirm that the burner is working If the first step goes thro' then boot the computer in safe mode(Coz, safe mode is the one in which computer can boot with the minimal set of driver) chk in device manager whether do u got any conflict in devices If not then try starting the IMAPI CD services and try it,if not then del Upper Filters and lower filters in registry at ur own risk
Posted on Jul 18, 2007
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 156 Answers
Transport lock off?
Posted on Dec 11, 2014
    New Friend:
  • 10 Answers
I suggest you to go through the CMOS and figure it out if the autodetect setting is enabled.....and try to check the data and power cable if ti 's properly installed...if it doesn't work you'd better update the BIOS through flashing the BIOS utility,,,,
Posted on Nov 04, 2014
    New Friend:
  • 5 Answers
All drivers for your system are at :- VAIO Digital Studio Desktop Computer
Posted on May 25, 2014
    Cheetah:
  • 90 Answers
Clean the laser lens with q-tip. Also, when mine does not burn a disc I lower the burn speed and it works.
Posted on Dec 08, 2013
I had the same problem. I removed the cd-rom and upgraded to a DVD/CD player and burner. I think it cost me about 80.00 which would be cheaper than buying a new computer.
This little computer is so versatile and I upgraded my OS and memory and it's still performing great.
Posted on Mar 23, 2008
Buy
Posted on Jan 26, 2008
    Scholar:
  • 161 Answers
Sometimes a unit may lose software needed to run and your system may need to be rerun. But more than likely your cd rom is bad and needs to be replaced. A cd burner would be a cheap good replacement for it. It would give you more speed and longer life and the ability to burn records and programs for safe keeping. Easy to change out on most computers.
Posted on Sep 06, 2007
I HAD THE SAME PROBLEM FEW YEARS AGO.THE BEST SOLUTION FOR THIS PROBLEM, TO DOWNLOAD THE DRIVER OF THAT COMPONENT.IF YOU HAVE THE RECOVERY CD's DOWNLOAD THE DRIVERS.FROM THE CD's. OR DOWNLOAD THEM FROM THE SONY WEB SITE..
Posted on Apr 05, 2007
  • 53 Answers
Faulty cd drive replace. also i would recomend cleaning all system fans. check system cables for corrcet fit. most of my corrections would be best performed by a local repair shop. Sony's are at best problematic.
4 Suggested Answers
SOURCE:
  • 20 Answers
SOURCE: Sony VAIO PCV-RX500 Cant get recovery cds to work
since she formatted the hard drive there is no drivers for your cd rom to work
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
san diego california 92127
Posted on Aug 21, 2009
vegakitten20
  • 685 Answers
SOURCE: I have a six year old sony vaio desktop. It has a
can you give me the name of the driver and i'll get you a site to download it
Posted on Nov 08, 2009
SOURCE: Sony Vaio sound...
Adam,
The sony VAIO Pcv-j200 only runs with Windows 2000, windows Me and windows xp. The current operating system Vista on your computer right now will work but some of the features of it may not. The link below shows all the drivers for your unit for diffent operating systems (not vista). What you can try to do is to download the audio driver for windows xp
http://esupport.sony.com/US/perl/swu-list.pl?mdl=PCVJ200&LOC=3
Posted on Apr 11, 2010
How to Boot Sony Vaio VGN-S460 Laptop without CD/DVD ROM and With bootable USB
If the BIOS does not have the USB as one of the boot options then you cannot boot up with an USB memory stick.
In this case you need to replace the CD/DVD drive with a new one.
Jan 17, 2013 | Sony VAIO CS VGN-CS220J/T Notebook
My CD-ROM doesn't work
ok what you can try is go to your device manager (type devmgmt.msc in run) uninstall and reinstall cd rom drive under opitcal devices
Jun 01, 2011 | Sony VAIO PCV-RX462DS PC Desktop
Can sony vaio VGN-FS742/W run windows 7?
Yes the Sony should run Win 7 although its designed for XP. For Win 7 to run properly you will need to max out the memory to 2GB.
I have installed Win 7 on plenty of older laptops without any problems. You won't be able to use the aero glass features (see through taskbar and window borders) as the graphics chipset doesn't support that feature but everything should work well once you have enough memory installed.
Regards.
Apr 21, 2011 | Sony VAIO VGN-FS742/W Notebook
Nov 07, 2009 | Sony VAIO PCV-RS720G (027242658103) PC...
CD won't eject from my Sony Vaio
grab a clib and stick it into the lil hole on the cd rom, it will eject it, don't make of this somthing regular, i mean don't do it often. one time it won be harm but every day it will.
Jun 30, 2009 | Sony Computers & Internet
Need sound driver for sony vaio model PCG-Z1RGP
Not sure what operating system you are using, but a quick Google search came up with this:
Sony does not offer audio drivers for this computer.
However, they do offer this:
Problem/Question:
Err Msg: Cannot play back the audio stream: no audio hardware is available, or the hardware is not responding.
Solution/Answer:
Please check if there is any exclamation mark (!) displayed in Sound, video and game controllers under Device Manager. If there is any exclamation mark (!) in the Sound Driver Devices, please reinstall the sound driver with the steps below:
1. Start up the computer.
2. Insert the last disc of the set of Recovery CD-ROM into the CD-ROM/DVD-ROM drive.
3. Double-click My Computer and double-click the CD-ROM/DVD-ROM drive
4. Double-click the VAIO folder and search for the Audio folder in the Device folder.
5. Double-click the Audio folder and double-click Setup.exe
6. Follow the on-screen instructions to install the Sound Driver.
7. After the installation is completed, remove the Recovery CD-ROM from the drive and restart the computer.
* If the problem persists after reinstallation of the Sound Driver, please follow the steps below to check if there is any latest device driver upgrades:
In the Downloads section, please select Notebook and proceed with the steps below:
1. Move the cursor to the relevant Notebook Series and click the model of the VAIO computer.
2. Locate any latest Sound drivers and proceed as per instructions on the screen.
* If the problem persists after performing the device driver upgrade, please contact the local Sony VAIO Helpdesk. For more information on how to contact your local Sony VAIO Helpdesk, please refer to either Customer Service Guide or Warranty Card that comes with the computer, or visit the Support Network of the VAIO website.
Jun 14, 2009 | Computers & Internet
Cd rom doesnt work at all
hi if ur system is provided with two drives then u can use the second drive.. if not then u have to go for a change of new rom..since u said that ur light wont even flash it means that ir drive doesnt detect that particular rom and it has got damaged....
thank u rate me
Feb 09, 2009 | Sony VAIO PCV-RX462DS PC Desktop
My DVD/CD-ROM DRIVES play DVD but not any CD or VCD
Okay, is it Blu-Ray?
Those drives tend to have a fault w/ non standard DVDs/Blu-Ray Discs
Thnks to Sony
try going to device manager, right click the drive, properties, 3 or 4th tab, roll back driver
Jan 12, 2009 | Sony Computers & Internet
1(888)476-6972
san diago rrc
16550 via esterillo
building 5
door two
Nov 05, 2008 | Sony VAIO PCV-RX500 PC Desktop
Sony Vaio pcg-frv37 dvd rom not working
you need a DVD burner in it to play and Burn DVD's
you have a CD Rom in it now.
Dec 17, 2007 | Sony VAIO FRV37 Notebook
Sony VAIO PCV-RX462DS PC Desktop Logo
327,935 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
