HI. My daughter has transfered video from the camcorder to our VCR before but we can't figure it out. We need to transfer the video to a VCR tape so that my parents can watch the video. Nothing is working. At most sometimes we can see a shadow of what the video is on the TV. We have a Panasonic PV-GS59
You will need a firewire card in your PC and firewire cable to connect your camera to the PC. you will also need a software like Windows movie maker which can help you to transfer videos from your camera to the PC.
If you're using a Windows Vista Operating System it'snot possible to transfer the videos from the Camcorder to the Computer using the USB connection. The videos from the tape camcorders cannot be transferred to Windows Vista Operating System as there is no USB Streaming ooption available on the Windows Vista Operating System. The Camcorder uses the USB Streaming function to transfer the videos to the Computer. You may wish to purchase a i.LINK/Firewire cable to connect the Camcorder to the Computer in order to transfer the videos from the Camcorder to the Computer. or There is an update for driver on the Sony website to transfer the videos from the Camcorder to the Computer using the USB cable. http://support.sony-europe.com/dime/downloads/downloads.aspx?site=odw_en_GB&m=DCR-HC42E&f=usbdrven_vista
You may also try installing the driver update for the Camcorder. The i.LINK cable gives a better video transfer qulaity than the USB transfer. The i.LINK cable used to connect the Camcorder to the computer depends on the number of pins available on the i.LINK/FIREWIRE port on the Computer. The i.LINK port on the Computer is a D shaped port which is labelled as i, DV, IEEE1394 and Firewire.
I had the same problem. I tried to solve this issue by buying a dvdmaker usb 2.0 gizmo. I have to use my VHSc cassette adapter and put it in the vcr.I connected the vcr and new gizmo to the pc and could see the video on my monitor- but no audio. So I tried plan b, which didn't requite any other purchases. I connected my old camcorder to my newer digital canon camcorder (which converts the signal from analog to digital) this in turn, is connected by a firewire to my pc. I can see (and hear) the video on the viewer of the camcorder. So far, it isn't being captured by my pc. Is this a Vista issue ? I don't know. I'm hopeful... I'll figure it out!
You must use the input select button on the vcr remote to turn on the jacks on the front or back of the vcr. If you need a remote, call the customer service number on the vcr to see if it is still available.
You need a download hardware from Pinnacle. www.pinacclesys.com You may use a simple one PC/TV card with software. If you are from India, you may get several options like www.monarch.com etc.
1. Using the A/V Cables provided, connect the proper end of the cable to the Camcorder where labeled A/V Jack
2. Connect the other end to the A/V inputs on the VCR. (Location of A/V jacks may vary by model)
3. You must activate the video mode on your VCR. Look for a button labeled: TV/VIDEO, INPUT, SOURCE, LINE IN, LINE 1, etc. (For more information, consult the User Manual for the VCR.)
4. Once you are able to view the camcorder playback on your television, press Record on the VCR and play on the Camcorder.
To connect your camcorder to a TV (or VCR), you'll need audio/video cables. These need to be run from the VIDEO and AUDIO jacks on the camcorder to the VIDEO and AUDIO inputs on the TV (or VCR).
Once cabling is completed, follow either of these scenarios:
When connecting the camcorder directly to the TV, turn on the TV and tune it to the video input channel by pressing the INPUT button on your remote control.
# When connecting the camcorder to a VCR that is already connected to a TV: Turn on the VCR and place it in the Line or Camera mode.
# Operate the TV as you normally do to see the signal coming from the VCR.
Select camcorders have an S-VIDEO jack, which offers higher video quality. Provided your TV or VCR has an S-VIDEO input jack, connect the camcorder to the TV or VCR using an S-VIDEO cable. Since the S-VIDEO cable only transfers video, you will also need to use an audio cable. Select the S-VIDEO input on your TV or VCR to view the signal coming from the camcorder.
buy that wire, check ur camcorder if it has 6pin or 4pin for firewire then check ur pc if it has firewire card...if not you have to purchase the ieee1394card. install it then connect your camcorder to pc through firewire and that will be it.. u also need to have a software for video capturing and editing like adobe, roxio, pinnacle , etc...hope that helps.
