LG LDS4821ST Stainless Steel 24 in. Built-in Dishwasher Logo
Posted on Jan 25, 2012
How to fix no power problem on LG Dishwasher LDS4821ST
Has no power
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 13, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1063
Points
LG lds4821 overheats filter board and burns it. Probably another part shorts and causes excessive current. Replacing the filter board makes dishwasher run but problem persists
  • Anonymous Feb 13, 2012
2 Related Answers
Anonymous
  • 443 Answers
  • Posted on Feb 21, 2010
SOURCE: Just installed a brand new LG LDS4821St
That's what factory warranty's are for, contact the place that you purchased it from or contact LG direct,
you paid for the warranty in the price of the dishwasher use it.
Good Luck !
Anonymous
  • 246 Answers
  • Posted on Oct 29, 2010
SOURCE: Can I purchase a left side panel for the LG
I'm not sure what you mean by ";eft side. I know applianceart.com has custom cut stainless steel pieces and if they can't do it, they have a matching faux stainless that was on HGTV a while ago. You should call them, they can probably get you what you need.
Lg dishwasher won't drain
The check valve prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. If the check valve is stuck closed, try cleaning it out and then replace it if necessary.
Where is the fusible link for my LG dishwasher?
If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work. The thermal fuse is usually located in the control panel on the control board or mounted to the bottom of the tank behind the lower panel. The thermal fuse can be checked for continuity.
Lg lds4821st
des ja vu.... all over again
Put belt on a LG lds4821st
Please check this link for tips to change the belt:Belt
1helpful
2answers
Just installed a brand new LG LDS4821St dishwasher. Washer will not drain. What do we do, no kink in hose
Good Luck !
Can I purchase a left side panel for the LG LDS4821st dishwasher? If so what is the cost, how soon could it be shipped and what is the shipping cost? Thank you, Gail
Lds4821st dishes comeout cloudy
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Top LG Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
