Gather the necessary tools: You'll need a set of replacement belts, a small screwdriver or a similar tool for removing screws, and possibly a pair of tweezers or needle-nose pliers.
Power off and unplug the cassette deck: Before you begin, ensure that the cassette deck is powered off and disconnected from any power source.
Remove the outer cover: Most cassette decks have a protective cover that can be removed to access the internal components. Use a small screwdriver to remove the screws holding the cover in place. Keep the screws in a safe place, as you'll need them later.
Locate the belts: Once the cover is removed, you should be able to see the internal mechanisms of the cassette deck, including the belts. The belts are typically made of rubber and are responsible for driving the tape transport mechanisms.
Identify the belts to be replaced: Inspect the belts and identify which ones need replacement. In some
Remove the old belts: Gently remove the old belts from their positions. You may need to use tweezers or needle-nose pliers to grasp and pull the belts off the pulleys. Take note of how the belts are positioned before removing them so that you can install the new belts correctly.
Install the new belts: Take the new belts and thread them around the appropriate pulleys and drive wheels. Refer to any service documentation or diagrams available for guidance if needed. Ensure that the belts are properly seated and aligned.
Test the belt tension: Once the new belts are installed, check their tension. They should be tight enough to drive the tape transport mechanisms without slipping but not so tight as to strain the components. Adjust the belt tension if necessary.
Reassemble the cassette deck: Carefully put the outer cover back onto the cassette deck and secure it in place using the screws you removed earlier. Ensure that all the screws are tightened but not overly tightened.
Test the cassette deck: Plug in the cassette deck and power it on. Test its functionality by inserting a cassette and playing it. Pay attention to the tape transport mechanisms to ensure that the new belts are operating correctly.
Buy a FISHER MC-630 AUDIO COMPONENT system Turntable Replacement Belts for your record player. Fix your broken FISHER MC-630 AUDIO ...
US$16.99 · In stock
Although Fisher has been a manufacturer of fine audio products for many years, like most audio, their products are mostly centered around digital systems rather than analog. It is doubtful you will find the belt you need. I would contact a TV repair shop. Many still have supplies of this type belt. In the mean time, since you are already inside the machine, try a rubber band about 3/4's the the length from the motor to the capstan. That should make a pretty good temporary fix for a while. Good luck!
The answer is YES! I'm not sure of where you are, but in the UK there are places like Maplins Electronics. It might also be useful if you have a service manual for the machine as well as it might tell you what size of belt you need.
There are many places on the web that sell belts and I'm sure it won't be too long before to have it running again.
good luck finding a part number for something this old. I might just measure the size (diameter) and width of the belt, and see if I couldn't get a generic replacement.
