Texas Instruments TI-84 Plus Calculator Logo
Posted on Oct 18, 2008
Graphing I am trying to graph the volume of a cylinder. formula for volume is V=Pir^2h and v=500. Please help!!!!
  • Anonymous Mar 22, 2014
    Mml loll ***
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
5594
Points
16
Calculators can not graph 3d unless you download a rendering application
How should I set the v-window when I enter my distance equation?
The Window parameters control the width and length of the graphing screen. The distance equation is a formula to use to calculate the distance between two points known by their coordinates. The window dimensions have nothing to do with calculations. Or maybe I don't understand the question.
3answers
Fibonacci formula won't graph, but will show table
Fibonacci sequence is the series of numbers 0, 1, 1, 2, 3, 5, 8, 13, 21, 34, ...
At first type Fibonacci equation in Y editor with condition x>=0 and then graphing it. See captured images with enlarged form of graph
3helpful
Graphing parabola
Parabolas are forms of X^2. Go to [Y=], then put in the formula of the parabola that you want.
7helpful
2answers
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Select Transfrm from the menu
  • Press 1:Uninstall
The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site
- doug garfinkel, Children's Day School
4answers
TI-82 graphing problem
You must press 2nd then "zoom", then go down to axes, and turn them on. Now your graph will work again.
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
