SOURCE: jura capresso
The dial on the upper right is all you need to do. Turn from the coffee cup to the water symbol. Water will pour out the spigot from the frother wand so put a cup under it. Close the tap when prompted by turning the dial back to the cup symbol
SOURCE: Jura Capresso Impressa S9 -water won't pull into the unit
We have the same problem after installing a new filter (after 5years of perfect usage & no problem or maintenan)ce. An engineer told us to take the filter out completely & try to draw off water...if it does, do a de-scale IMMEDIATELY (using only recommended product) because the machine may be calcified. If that doesn't work, it may be the sprung sensor under the water carriage which may be blocked(with limescale) or broken...OR the little mesh sensor in the main body of the machine (which is located under the water filter). I am trying this tonight, otherwise its an engineer callout for collection & repair!
SOURCE: my jura capresso says system fill...it makes a lot of noise
System fill is usually when the machine auto solenoid fill valve is putting water into the boiler. If it is making noise then the solenoid is clogged or there is no water getting to the solenoid.
Please dont forget to vote this answer was helpful
Many thanks
