What is your Alcatel Phone Model,You need to specify that,get that Unlock code from here Theunlockspot.com
and unlock it from network lock.
SOURCE: N95 Unlock from call barring
call barring is not governed by cell phone itself .. the opertor controls call barring and diverting . contact customer care and tell detils about the problem to them
SOURCE: unlocking code for sony ericsson z320i
Solution for your Sony Ericsson Z320i :
Before trying anything else, contact your service provider and ask for an unlock code.
Usually, if you've been a customer of theirs for some time, they will provide you with an unlock code for free. This is, by far, the best way to get your phone unlocked.
Download software to generate the unlocking code. Software is available on some websites for free and some pay websites that also offer support if things go wrong.
See external links below.
Find the Serial number of the cell phone, also known as your IMEI number.
Using the software you have downloaded, enter in your Manufacturer (which is in this case Nokia), your model number, and your IMEI number.
Also enter your country and the Network. Calculate the code, this may be different depending on which software you are using. If your phone is the Nokia 6300 phone, select the model 6300, they are the same phone.
#pw+403927744443466+7#
Remove the SIM card from your Nokia phone.
This is typically done by removing the back cover of the phone and removing the battery and sliding the card out. Put the battery back in and power the phone on.
You will see a message "Insert SIM Card".
Enter all of the characters you see in your code, including the # symbols.
To get a 'p' press * 3 times, to get a '+' press the * key 2 times, to get a 'w' press the * key 4 times.
Disregard any spaces in the code.
In order to unlock your phone you generally need to enter only one code.
Start with the first one. If your phone is not unlocked by typing the first code (MCC+MNC), use code "7" (Multilock)
Once you have finished entering a code that works you should see a message that says "SIM is not restricted" or "Restriction off" message depending on your model.
If not, try entering another code. Message "Cannot undo restrictions" means the phone is "hard-locked" and cannot be unlocked by code.
Tips
Unlocking only applies to GSM phones, phones using other cellular technologies, cannot be unlocked without special software and hardware.
Switch off the phone. Hold the keys "3", "*" and "Call" and switch the phone on. Keep the buttons held down till you see the word "Formatting..." on the screen. Make sure that the battery is full charged before you attempt this. This should reset the phone lock code.
Warnings
Attempting to unlock your phone is done at your own risk.
Although unlocking your phone is legal, some cell phone operators might choose to void your warranty should you unlock your phone (then again, some cell phone operators won't mind).
Most phones only allow you to try a certain number of unlock tries, Nokia phones have a limit of 5 tries.
After that, the phone becomes "hard-locked", meaning it cannot be unlocked without using special equipment.
Most of the newer phones will not work with the codes generated by the free unlock programs.
You can get a free unlock code generator software free from here :
http://unlock.nokiafree.org/
You can also download from here :
http://unlock.nokiafree.org/NokiaFREE_v310_Nokia_unlock_codes_calculator.zip
You can check this :
http://www.wikihow.com/Unlock-Your-Nokia-Cell-Phone
The software name has the Nokis but you can choose Sony or this purpose & selct CMD-C1 or CMD-CD5.
Enter the IMEI lick on calculate.
Good Luck.
Live, Love, Laugh.
SOURCE: LG KG220 Unlock code
I did u find the unlock code for this phone I am after this also rang optus and they will unlock for bloody $80.00 I cannot believe this it really makes me so mad
Kim
[email protected]
