New alternator new battery still showing 11 votlts
Does the alternator check light light up when you turn the ignition on?
If not the connection from the dash board to the alternator is not there for what ever reason, might be the wiring loom of the bulb, or the alternator it self. If this all works its worth to check Ground between alternator and battery, should be around 0 Ohm, and check also the B+ wire from the back of the alternator to + terminal of the battery, this should be also 0Ohm.
