Wire not feeding correctly
Check for the correct tip size first. Too small or too large portal will jam wire in the tip. Check for correct wire speed for amperage used, too fast or too slow coupled with the distance from work piece will do the same. Check for wire condition, if the wire is rusted......you do the math. Check polarity......DECEP vs. DECEN for the type of materials welded. ARE YOU USING AN ANTI-SPATTER AGENT? Build-up of spatter can cause early arc. Lastly, is the wire tension too high? The wire should not feed at all even with the motor drive unit running if the wire has fused to the tip, that leads to a kinking of the wire behind the feeder (spool side).......check also the backlash adjustment to keep the wire from spinning off the spool under load. Too tight will cause the outer cladding of the wire to strip off the core wire which will cause the core to adhere to the tip.
