I bought this HTC, and when I put it on charger blue light is start to lit on the corner of speaker. I charged it for an hour, then I try method: charge-pull out battery-pull out charger-pull in charger-pull in battery. This is worked. And I saw like hi wakeup, and I try some menus and applications, everything worked fine. I leave him to charge and for an half an hour there whas black on display and orange led brighting. I try to turn him on, and nothing hapend. Pull charger out and orange led goes off. That is all. First nothing, and after blue led again. First method don't work anymore. Help what to do! Previous ipaq I can't repair, please help me now. I need phone!
SOURCE: My HTC smartphone wont turn on or charge and when
Have you tried leaving it to charge (with the red light on) for a few hours. The red light usually means a completely drained battery that needs a few minutes/hours to recharge.
Also, try cleaning the battery connectors with a rough toothbrush...
SOURCE: HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
SOURCE: My LCD screen is cracked but the phone still works great
you will need to take the phone to a mobile service center and have them replaced it for you for a fee.
SOURCE: HTC S710 Smartphone not switching on
The battery is
flat.
If the battery is very
flat sometimes the phone will not start charging or turn on even when a power
cable is connected.
This worked for me:
- Remove battery
- Insert power
cable/usb cable
- Orange charge
light should start flashing
- Re-insert battery
- Leave phone charge
for a couple of hours
- Turn on
SOURCE: Blue On G1
ok i had this isssue and figure out what to do. this is all afterm you know that you have a good charger and or battery.
1. completely turn of phone unplug charger.
2. take and put battery back in phone and plug charger.
3. hold hit camera button and power buton. phone will come on if the update was washed it will come straight on. if not you will see the blue LED dont worry yet. just keep holding for 15 sec.
4. while phone blue LED is still on hit and hold (drum Role) menu and track ball for 15 sec.
5. now unplug charger and take out battery. wait 10 sec
6. now put battery back in and leave charger off. and turn on. unless you was in middle of update and hardware failed this WILL bring your G1 back up and running.
hope this helps everyone . MIll$tronics signing out.
For a few days I found way how to turn on this G1 everyitime. I am happy becourse is winter now and cold weather. When I chill phone its starts always, and working. When I wrote previous message, and when I saw he working, it's work really, and I tipped some menus, and he unfotunatly turn off. In meenwhile I rooted him and now he answering me for code to unlock from T-mobile. Can it be that he locks becouse rooting or backing to RC29? If it possible he was unlocked, can I bypass that message, and logging to Google account?
