Question about Casio FX570ES Scientific Calculator
Fx-570 ES how can i get comma is the results for example 100,000,000. Comma after every three digits?
  • Casio Master
  • 8,081 Answers
Sorry but you cannot. You can change the decimal mark from dot to comma but you cannot have the calculator separate the digits between thousands (thousands separator).
Posted on Jan 25, 2012
2 Suggested Answers
SOURCE:
  • 457 Answers
SOURCE: my calculator casio fx 350ES doesnt give me right
Did you enter a dot as a separator for the thousands? If yes, this is the error. The calculator interprets all digits following the dot as fractions of decimals.
So you enter 220.000 meaning 220 thousand, your calculator gets it as 220 comma 0, and thats where your three zeros go...
To make it right, enter your numbers as 220000 - 100000 and you'll get 120000 as result.
Posted on Jan 10, 2011
Hi there. I'm using Casio FX-570ES scientific calculator. I would be glad if you could guide me as to how to obtain derivative of a polynomial expression e.g. y=12(x^2+6)^5
Here is an example. Instead of SIN(X) insert your polynomials.
The syntax of the command is
where function is the expression you are differentiating
x is the value of variable x at which you are evaluating the derivative, and tol is the tolerance (the error) you are willing to tolerate in the result.
If you do not want to specify a tolerance just omit the last comma and tol.
To enter the command d/dx you use key sequence [SHIFT][Integral]
To enter the symbol x in the expression you press [ALPHA][ ) ]
To enter a comma you use [SHIFT] [ ) ]
To enter a power of 10 in the tolerance use [x10^X] key
Example : Calculate
The key sequence is as follows
[SHIFT] [Integral] 3 [ALPHA] [ ) ] [X^2] [-] 5 [ALPHA] [ ) ] +2 [SHIFT] [ ) ] 2 [SHIFT] [ ) ] 1 [x10^X] [(-)] 12 ) [=]
DO NOT confuse [SHIFT] [ ) ] which enters the comma and [ALPHA] [ ) ] which enters the variable X.
May 28, 2011 | Casio FX-115ES Scientific Calculator
How to interpolate in CASIO fx 991 ES
its simple
press mode
3;stat
2;A+Bx
l x l y l
l 2 l 4.6 l
l 4 l 5.9 l
press; AC
press;5.9
press; shift
press;1
press;7 (reg)
press;5 (comma)
press;=
u will get ans
Feb 08, 2011 | Casio FX-115ES Scientific Calculator
Fx-82es how we seperate digits with the help of comma. like 123,456,789. Is the comma sepration option is available in Fx 82es?
Yes,it's possible to program the Fx-82es to separate the digits with the help of comma.
PLEASE FOLLOW THE INSTRUCTION CAREFULLY.
If you make a mistake then please turn the calculator off and start over again.
Turn the calculator on.
GO TO Display setup screen
Disp 1
You will has two options
1 for DOT (that's not what you want)
2 for Comma (please press 2 and enter/triangle pointing to the right)
Please let me know are you able to get to setup mode and make the comma change on reply.
Jan 24, 2011 | Casio FX-300MS Calculator
My calculator casio fx 350ES doesnt give me right anwser.this is the anwser from my calculator when i inter this numbers 220 000-100 000=120 (there should be 3 more zeros).it happens all the time when i...
Jan 10, 2011 | Casio FX-115ES Scientific Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
How to find derivatives using fx115-es
Example : Calculate
Oct 29, 2010 | Casio FX-115ES Scientific Calculator
Im not sure on how to caculate derivatives on the calculator, help would be appreciated
If you do not want to specify a tolerance just the last comma and tol.
Example : Calculate
Aug 27, 2010 | Casio FX-115ES Scientific Calculator
Can i calculate calculus using fx-991ms
If you want to get an answer like 1/2X for d/dx(X^2), you will have to purchase a CAS calculator like Casio's Algebra FX-2 or Classpad. TI series calculators also have CAS.
However, you can calculate the numerical values of derivatives and integrals only.
To calculate the value of a proper integral:
  1. Press the 'ON' key;
  2. Press the Integral key b8325f5.jpg;
  3. Enter your expression (example X^2+X-3 etc);
  4. Press the 'comma' key after your expression;
  5. Input the first limit after comma, input comma again after first limit;
  6. Close brackets;
  7. Press the equals key, display may return after a while with the answer.
for eg to calculate xdx from 0 to 2, input as follows:
dx(X,0,2)
To calculate derivative at a point:
  1. Press Shift and then the integration key.
  2. Enter your function;
  3. Input comma;
  4. input the point at which you want to evaluate the derivative;
  5. Close bracket and press enter.
Example, to calculate d/dx X^2 at 3 input:
SHIFT+dx key X^2,3)
Display looks like this: d/dx(X^2,3).
Oct 23, 2009 | Casio FX-300MS Calculator
When I turn my 12c on it has a comma instead of a period.
The comma is a three-digit separator that appears if number with many digits are displayed ( millions, billions). Since it is a financial calculator designed for money calculations, the comma can be helpful.
There is nothing in the manual that suggests that the three-digit separator can be removed. It can however be replaced by the point as in European Countries (especially France) where the decimal mark is the point and the three-digit separator the comma.
In short. I do not think you can get rid of the comma.
Hope you can learn to live with it.
May 06, 2009 | HP 12c Calculator
Casio FX570ES Scientific Calculator Logo
2,552 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Colin Stickland
Colin Stickland
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
