2" of white thin lines across top of screen, perfect picture after lines but they cross head tops
Sounds like it might be dust
This sounds like theres a capacitor somewhere in the vertical sweep circuit. You can replace the capacitor if you have a soldering iron and some electronic experience on trouble shooting tv sets. It is most likely from what you described the capacitor off the high voltage transformer that supplys the b+ to the vertical output IC. A repair person should be able to give ya a ball park on the cost as Im thinking somewhere from 85 to 135 Bucks depending on if theres only one cap goiung bad or could be a couple or more starting to dry up. So its your ball now .. Do you wanna spend that much to repair the set Do you like the set? is the set over 3 to 5 years old? Its up to you. Good Luck
It seems the lines are getting spreading down more after time
I have the same problem but on an older model - NO. STV2556 and after a few days it turned into no picture just a white line in the middle. Im trying to find a wire diagram showing those exact wires and diods.
I need a diagram of an OrionT.V. NO. STV2556 to replace these diods. And what specific diods do I need.
i have the same exact same prob, would you know which caps could be the prob and where they are located on the board and how to check it with volt,ohm meter to tell which it is. Soldering and getting the parts is no prob i can get just about any cap for 1 to 5 dollar, just never worked on tv before.
i have exact same prob, could you tell me which cap numbers it could be like c404 if needed i could attach picture of board.
