It's a lost cause. The A540 works with SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You need to stay with SD cards, 2GB and smaller.
When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Mc9090 does not have a battery door?!
You should try a reflash by SD card or Activesync, you will need access to support.symbol.com and possibly a service contract to access the firmware.
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
3 times blink error code shows Lamp Door is not seated / fixed properly, please recheck it and make sure that door close safety switch is pressed as this switch sends error signal to system control chip.
