Vtech 5.8GHz Cordless Phone with Digital Answering System Logo
Posted on Jul 15, 2017
Vtech Mirage a110 cordless phone
I have the above phone with an additonal charging base and two phones.
Both phones register with the main base and ring when a call comes in but I can't hear any calls, and if I try to ring a number, all I can hear is what sounds like an engaged tone. If I go into the base menu and try to select either "Priority" or "Pin Prot" I get "Not Available".
Any help would be most welcome
Bill Gordon
1 Related Answer
Anonymous
  • Posted on Jun 26, 2008
SOURCE: Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
I replaced the battery and fully charged it. The display says "connecting" then, "place handset in Base to register". It still does not work
possible bad connection base to phone, sharplely take phone on and off base repeatedly, to try and get good contact, ensure contacts(probes) on base are not stuck in or out ,
press the helpful button
VTech Phone User Manuals VTech Cordless Phones
VTech Answering Machine User Manual PDF documents
How do I register my vetch cordless phone?
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.Step 1: Place the handset in the base or charger. If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in the base or charger. Step 2: On the telephone base, press and hold FIND HANDSET for approximately four seconds.
Product Registration - VTech® Cordless Phones
https://www.vtechphones.com/.../product-re...
VTech Communications Inc.Vtech DECT 6.0 cordless phones are among the most advanced and innovative homephones on the ... Product Registration. How do I register my product?
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
i registered my handset but im not able to call and answer call from my ... you lose your phone you have to de register allphones and start over.
My vtech phone say not registered and see manual #cs6114
VTech Communications Inc.My handset displays Not Registered. ... If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in ...
My vtech phone says not registered and not sure why ... - Fixya
www.fixya.com/support/t10092346-vtech_phone_says_not
Aug 13, 2011 - my vtech phone says not registered and not sure why and how come? can ... See page 26 of the manual for detailed instructions on HOW TO ...
My vtech dect 6.0 phone says not registered how do i fix it ...
www.fixya.com/.../t7993579-vtech_dect_6_0_phone_says_not_registere...
Jan 26, 2011 - my vtech dect 6.0 phone says not registered how do i fix it - VtechDECT 6.0 ... If you click on the above it will take you through to the manual, hope i`ve helped .... See all Vtech DECT 6.0 Digital Cordless Phone Questions ...
? 3:21
My phone says no line plz help me. Been without a ... VTechuser manual had no instructions to set up an ...
[PDF]User's manual - Vtp-media.com
How do I register a cs6114 phone
Do you need to register a handset? Make sure the battery is fully charged on the handset and remove the handset from the base. With the phone not in use, press and hold the Find Handset button on the base. After about 4 seconds, the In Use light should light up. Now press the # key on the handset that you need to register. It should say Registering and then complete the registration within 60 seconds. This will only work if the base has power and is connected to a working phone line.
If you need to register the phone with Vtech, go to http://www.vtechphones.com/support/general/product-registration .
I hope this helps.
1helpful
2answers
Vtech Dect 6.0 says not registered. how do I register?
Instructions for registering additional new handsets on VTech Model DS6151: Place additional handset on main base. Press HOLD on main base and # on handset. Asks you to de-register. Press no. Registration of additional handset takes place.
1helpful
Working one set of Vtech 6041 cordless phone set with another?
I have the vtech dect6.0 with one answering system and two remote docking systems.I can phone out from the remotes but cannot receive incoming calls from the remote.When I pick up the remote to receive the phone immediately shuts off.
1helpful
Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
2answers
Not Registered Problem
I had the same problem and I JUST fixed it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Top Vtech Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
