SOURCE: lights just flash on controller and wont move jet 3 wheel chair
Do they flash in series? Like ten flashes then a pause then ten flashes?
SOURCE: All six lights blink on my Jet 3
I just had the same problem with my uncle's power chair. The number of "blinks" indicates a problem code to the technicians. My chair needed the joystick control assembly replaced. Once replaced, evrything was back to normal. 'Not a cheap fix but much needed. Good luck my friend!!
SOURCE: My Jazzy select wheelchair does not run
you move the joystick and can hear something quicking in the motors
SOURCE: wheelchair problem
sounds like you might have locked joystick by mistake. Try pressing and holding down the on/off switch for 5 seconds.
SOURCE: working on a pride wheelchair that i just put (2)
First, make sure that the motors are both engaged and not in freewheel, and that the charger is unplugged. If it is a constant flash without pause, this is usually an indication that the joystick is "out of neutral", a problem caused by hitting running the joystick handle under a table, for instance, of moisture in the joystick itself. If it is a series of flashes, like 4, pause repeat, then you have a fault somewhere else in the chair. Here's a link to the flash codes for your controller. http://www.dynamiccontrols.com/index.cfm/3,73,237/dna-flash-codes-0307.pdf The flashes, types and manner of flash need to be better described in your posting. Good luck.
