Pieter
the manual covers this.
hole the menu button in for 15seonds release and unlocked.
that is a generic answer. the manual is free to read on online.
1st google hit. and page 8
https://www.manualslib.com/manual/243261/Lg-W1934s-Bn.html?page=8
SOURCE: Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
SOURCE: Lg Flatron W1934S Moniter Problems
You could have a faulty inverter board or a faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp and the CCFL lamp is a mini fluro tube.
Have a look at LCD Patrs WEB site for service, parts and DIY info Use this link to their WEB site :-
www.lcdparts.net
SOURCE: my lg flatron model w1934s was working fine but
Try turning it off and hold the power switch in for about a 30 seconds. This may help to reset the monitor. Afterwards, try and power it up again.
SOURCE: LG FLATRON W1934S
hi,
check first if the connector has no connector pins wha are broken or shifted. if not chack cable for hard nobs or turns maybe cable is interrupted.
take other schreen to check VGA output of PC.
if all this not helps mail me back
greetings cis
SOURCE: MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
