Clock is about 10 years old.
I'm not sure if we have the same clock. Mine has needed batteries for a while, finally picked them up today. Once the batteries were in I had to reset the Zone by pressing and holding "CLK/CAL" button until the time blinks, then release and push the button until you see one single number on there... then set the zone. There is info in the user's guide (I can't find mine) so I kept changing until the time was correct. Now works perfectly.
SOURCE: Centrios Atomic Desk Clock/Temperature
It's so simple. Go to http://www.centrios.com/ >Timekeepers >Support >Online Support >Centrios Manual> Category"Clocks" >Model"6316006/C864" >Manual"English" >Download.
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: atomic clock reception
I guess the battery has run out on you. change the battery and you are good to go. I got to warn you though, if you are skittish on taking a good risk, do not try to change the battery yourself. It is a little piece of complex machinery. I have the same problem a while ago. I decided to change the battery myself after the watch repairman tried to sell me a new watch. And you know what, I'm glad I did. My atomic watch is working fine again.
SOURCE: instructions for setting Sharp Atomic clock
Remove backup battaries
and re insert new/or-goodbattaries in the battarey comportmane as correct +/- sign.
show the time if its start from 12:00AM
press startbutton -get time adjust mode -select correct Time and press set to mnormal mode.
SOURCE: I can't set the clock. The hands keep turning and
Look at the bottom right of the back of the clock and find the "M Set" button. Simply hold it down and the clock will move (very slowly). When it gets to the correct time, let go of the button. After that, the radio controlled shoul dcontrol should correct any minor differences in time.
Jim
