Question about Olympus WS-300M Digital Voice Recorder
Won't turn on
The battery is new and even when I plug it on to my comp it wont open the files, doesn't even appear on My Computer file. It worked just fine both days before but I noticed that it just stopped working. Its not on hold, and its at least a bit over a year old. I have tried almost everything except whacking it, shocking it and dissecting it. I don't put it near anything that can break it, when its in my bag its in a pocket for my pen drives.
  • Anonymous May 23, 2009
    It's hardly going to be a battery problem if it doesn't even work when you plug it into the computer. I have the same problem - It was just over a year old - it worked the week before and just stopped working out of the blue - I keep it in a protective case and had had no previous problems - the thing is with technology having moved on so much this recorder is half the price to buy new now and is probably cheaper to replace than to repair - I am very disappointed with its longevity as it cost over £100 new but now you can but it new on Amazon now for about £58. it is a shame as it was a great little recorder.
Hey i also had the same problem and had no clue what to do, when i checked i had stupidly put the battery in the wrong way!! this may not be your problem but you could still give it a try! : )
Posted on Feb 28, 2009
6ya staff
SOURCE:
Wont transfer pics to comp
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
May 07, 2012 | Kodak EasyShare C315 Digital Camera
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Neo Notebook model no. LC89-black screen only.
  1. All Operating Systems
    • 1 Remove any discs in the computer.
    • 2 Hold the power button down until the computer turns off.
    • 3 Press the power button to turn the computer on. If this doesn't work, proceed to step four.
    • 4 Remove the battery and unplug the netbook. Wait 30 seconds.
    • 5 Reinstall the battery and plug in the netbook.
    • 6 Press the power button for ten seconds. If this doesn't work, proceed to step 7.
    • 7 Insert the end of a paperclip into the reset button to reset the netbook. The reset button is a small hole that usually appears next to the USB and other ports.
    Windows 7
    • 1 Create a new Notepad file.
    • 2 Type this code:
      taskkill /F /IM dwm.exe
    • 3 Save the file as displayfix.bat in the following location: C:/ProgramData/Microsoft/Windows/Start Menu/Programs/Startup
    • 4 Restart your computer.
Sep 20, 2011 | Computers & Internet
Aspire 5100 wont save when i shut down
It appears that the C dirve is using 98% of space. Let us try to delete some temporary files, to do so, click Start Menu> Run> type %temp% and hit enter. It will open the temporary folder, delete all the files listed in this folder. Now, again click Start> Run> type prefetch and hit enter, it will open the prefetch folder, delete all the files listed on it. It should take care of the issue.
May 20, 2010 | Acer Aspire 5100 Notebook
Can't download my pics from my cam to my comp !!!!!
Jun 15, 2009 | Olympus FE-210 Digital Camera
Files in player not showing up from computer
hey the music is on here but it wont play. basically when i plug it up to the computer the music on here plays btu it wont show on the ipod or i cant find the music on the ipod.
May 24, 2009 | Audio Players & Recorders
My sansa e260 wont show the songs i just added from my comp
On your player, try going to Settings, USB Mode, and switch it to MSC if you didn't. Now plug your player in and go to "My computer", and open up your player. It is now used as a storage device, but you can still edit the music section (including the video section). Now try deleting all the music inside and create a new folder for your music. Now drag all your music files inside the folder you just made (this will not affect your album, genre, etc categories). After that, unplug your device and try the music files to see if they work. If they still don't work, I suggest you just format (reset) your player. To do that, simply plug your device on your computer. Then go to "My Computer" and when you see the device there, right click it and click on "Format...". Before that, if you don't want to loose any of your files (music, video, etc), I suggest you store them in your PC and put them back in your player after the reset.
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Ext WD500GB drive not being recognised by my computer,but seen in device manager
try downloading this and and scan may be it might locate yr drive since windows can still see it in device manager. and with these u can recover even deleted and formated files. try it
http://services.seagate.com its trial version so u can get a full version n pay little or find similar software but i know yr drive can still work fine its just that we r missing something here.
thank u
May 27, 2008 | Computers & Internet
Deleted files
yeah unless you still have the files on your computer. but if you dont just download them all over again.:( I know it sucks but i think it will work
Feb 05, 2008 | iLO (2 GB) MP3 Player
I have Sanso m250 2.0gb mobel. Logo screen is appearing when i power on after that i am unable to play the mp3 songs or play FM Radio etc..
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. I do not know if this will work on other Sansa m200 type .mp3 players. You can start over with your playlists. This has worked for me.
Dec 23, 2007 | SanDisk Sansa m250 MP3 Player
Olympus WS-300M Digital Voice Recorder Logo
123 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
