SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
SOURCE: Whirlpool side by side refrigerator not defrosting.
take back panel off inside freezer. check continuity thro heater and thermal fuse in series with heater
SOURCE: Which is better pulse defrost or adaptive defrost?
pulse and adaptive def actuall work in tandem with one another. what happens is the computer will put the refrig into a short def cycle and test how long it takes the termination switch to open this determines when it is time for the unit to go into a full term def the next time. adaptive defrost looks for the number of door openings and how long it takes for the def termination switch to open during a regular defrost. most units will go into def every -12 hours with adaptive if the conditions are right it can go as long as 2 or 3 days between def cycles. both systems are very relaible and trouble free. the pulse defrost is available on higer end electronic control refrig and is also adaptive defrost system as well. whirlpool also has adaptive defrost only available on their midline units as well as some higher end manual control units.\\
sorry for the defrost class peyton..
SOURCE: About every 2 months the defrost drain gets plugged
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out
with hot water and clorox may help. Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
Take a bare copper wire and wrap it around a fin near the
heater and put the other end a few inches down the drain. The heat convection
may prevent it from freezing.
SOURCE: refrigerator cooling but doesnt get cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Check out the water running tip...
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Joan a model number would help us a lot to assist you
