I have a coleman powermate 4000 watt generator, after 5 mins it just cuts off, then i can crank it right back up and it will run 5 more mins then cuts off again
I have a old Coleman 4000 it will run up to a hour or better then shuts down and and I can start it back up runs for another hour or so does same thing I have plenty of oil in it what's the problemI have a old Coleman 4000 it will run up to a hour or better then shuts down and and I can start it back up runs for another hour or so does same thing I have plenty of oil in it what's the problem
You can't post conmments that contain an email address.
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
? 4:35 https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Your generator is a welder?? Yikes, the 220 volts coming out of the genny is not the same as the 220 volts running a welder, it is, but it isn't, the 220 volts used to run the welder are transformed into DC, in the 50 -150 amp range, the 220 volts coming out of your genny is 220 volts, AC, at 30-40-50 amps. Now exactly how were you welding with 220 volts AC? Remove anything plugged into the genny, check the oil, check the gas, make sure it is fresh, check the breakers, check the fuses, get it running, now don't try to weld with it again. Unless you have a big welder to plug into it and I wouldn't even do that because of the generator spikes. I might be wrong, but I have never seen a genny with a welder on it for home use.
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
Try reversing the polarity of the battery you're using to flash the generator. Also try running the generator for about 30 min with a load on it after flashing.
