The Manual for your Hotpoint Aquarius WMAL641 Washing Machinehttp://www.thegascompany.ie/iopen24/washing-machine-hotpoint-aquarius-wmal641-1400-spin-p-969807.html
Found one over here - Hotpoint Aquarius Washing Machine Manual
SOURCE: lights flashing / flickering on face on controls-machine not work
This is normally a signal that is for a control fault. you will need to pull the power and shut this unit down for 5 minute.. if the unit continues to flash after this reset, you will need to replace the control board/timer in this case. it has failed.
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
SOURCE: url for users manual for hotpoint WML520P ?
Go to>
WWW.HOTPOINTSERVICE.CO.UK
In the menu click on>
HOTPOINT USER MANUALS
In the search box enter in uppper case your model number without the P
You should now be able to download the instructions.
Please rate my solution.
Thankyou.
SOURCE: control panel lights ALL flashing on hotpoint aquarius washing ma
my lights are all flashing on my control panel, its takes water in then pumps out straighaway doesnt wash or spin i have changed the brushes so i know it isnt that please help it only about 3 years old
