The tv has a loud high pitched whine in it. No other problems
Hi If you can hear any buzzing from more than
a few feet then the TV is defective and needs to be replaced. Buzzing is a
common defect among plasma TVs regardless of brand. It has nothing to do with
the plasma cells working; usually it's a defective board or a power supply
problem or something like that. Also check this related article in the
given link to get a detailed idea:- http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view_us.jsp?AT_ID=14966&PROD_ID= Thanks for contacting fixya.com Please do get back to us for further
query.
SOURCE: sky 42 inch plasma tv
hi all .ive had the same problem,a thick black line down screen.sometimes it flickers from top to bottom and other permantly in view.but i have solved it.forget your ic boards and taking apart tv.have you got either a ps3 or wii connected to tv.if so unplug power lead from socket and relocate in seperate socket.make sure the lead is completely free of any other leads and you might just find this works.i think the power lead creates some sort of frequency that the tv picks up .good luck hope it works
SOURCE: How to setup my VCR to record programs from my
You will take the video out and audio out from the tv, plug those into video in and audio in on the vcr, then put the channel on the vcr to line in, if your using the front, it will say front. Don't forget, DO NOT change the channel on the tv nor shut it off while recording this way or you won't have a recording.
SOURCE: help my 42 inch panansonic plasma tv will not turn
Hi:
Replace or have the power supply serviced, the most common failure with panasonic plasmas is tthe power supply.
SOURCE: I have a Viera 42 inch plasma tv (model
the problem is the panel is going bad. usually not economical to repair. repair usually runs as much as a new one.
