NV55C Gateway Laptop with Windows 7 - 64 bit. - Just will not connect to my Belikin Dual router. I've updated all drivers, updated windows and removed firewalls. I've done the full CD recovery 6 times, downloaded patches, net work adapter software from the gateway web site. Installed all newer drivers again. The Belkin router works fine on 2 other laptops,even a laptop I've had turned off for over a year. YET this NV55C Gateway with 6GB memory and 500GB HDD will not connect to this router. It does by the way see the network, the lap top asks for the "Router Key code", which I place in the field, but after 10 seconds says its unable to connect? I've worked on the router, reset the parameters and the two other laptops work fine........
Does your WiFi work on the laptop work in another place... Starbucks for example? If so, then there is a software security issue with the router, you will need to call the ISP for adjust the settings. If you PC doesn't work with wifi at Starbucks then you have a software issue with your laptop. Go to MY Computer, Hardware/Devices and look for any yellow marks. There will probably be one where the wifi is located. (Expand all the devices by clicking on the plus "+ signs. Find the wifi modem, there are many mfrs; Broadcom and Atheros are two ones. Go into the submenus and driver update too and write everything down you find. The most important things are the description, model number, software version and version date. Navigate to the hardware mfrs site and download and install the newest drivers for the wifi modem. Re-boot and try again to establish a connection.
SOURCE: wireless adapter on Gateway W350A laptop not
kjhjvxbjhxjfhxjvjBcnbcvkhjchjdhjhdfjhdjhjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjjj2
SOURCE: Dual Monitor Support for Gateway Laptop
Search on google for does gateway software support dual monitoring.
SOURCE: Drivers for Gateway 4530GZ
ok what you do make sure its a genuine copy then load internet explorer nad go on to windwos update and iff yu dont have a internet connection of any sort on it then go tohttp://support.gateway.com/support/drivers/search.asp?st=pn¶m=4095 this should solve all your problems tht is all the driver s nown to man for that cmputer
SOURCE: wireless internet on laptop
You need an external WIRELESS ROUTER or MODEM ( provided by AT&T ). After this AT&T router configuration you needs to do configuration at your laptop using CONNECTION SETUP wizard for Wireless Networks & Devices.
Then you can set IP addresses & then you will be connected to it. I hope above steps will help you.
Rate the solution if it was helpful to you...
With Regrards,
Shyny
SOURCE: Driver not working for Gateway MX6625 laptop
this is a windows problem, there is a special hotfix for this problem. contact microsoft technical support, as they are the only one who can give you this hotfix legitimately.
