Olympus VN-3100PC Digital Voice Recorder Logo
Posted on Oct 17, 2008
Vista and CD's
In looking at the VN-3100PC it does not show Vista Home Premium as a supported OS, will it work with Vista? Also I'm recording a class and want to burn it to a CD, can this be done with this recorder and Vista? Thanks!
  • 2 more comments
  • Anonymous Oct 18, 2008
    vista problem
  • hagengrd Dec 21, 2008
    I have installed the CD for the VN-3100PC and the Vista update, but my computer still will not recognize the recorder.
  • amercere Jan 03, 2009
    Same thing. If anyone has a fix for it, I'd appreciate it greatly!
  • Anonymous Mar 10, 2009
    I have the same problem and understand that the recorder is not compatable with Windows Vista 64 bit only the 32 bit. I have to by a new one.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 22, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
353
Points
This is the info off their site regarding their vista update. It has worked on my new laptop.
However, the VN-3100PC is not compatible with anything that runs 64 bit.The following is the url and the info regarding Vista Compatibility.
<Best to all>
http://www.olympusamerica.com/cpg_section/cpg_support_downloads.asp?id=1272&os=w
This download updates the Digital Wave Player software bundled with Olympus VN-*PC series digital voice recorders from version 2.1.1 to 2.1.4. It enables Digital Wave Player versions 2.0 and later to run on Windows Vista systems
6helpful
2answers
Olympus VN-3100PC drivers for Vista x64
Unfortunately there is no way to make this recorder compatible to Vista 64 bit operating system. You may want to call Olympus customer service and see if they can do an exchange to a VN-3200PC or a VN-5200PC as these recorders are both compatible to that operating system. Their telephone number is 800-622-6372 option 2 and then option 3.
2helpful
Need to locate a Driver for digital recorder
There are many steps in installing Digital Wave Player on VISTA 32 bit operating systems only, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
1helpful
2answers
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
How can I download my VN-3100PC olympus digital recorder in my new vista laptop? I already lost the cd software.
contact the olympus tech support. they will send you a download, but it does not work on 64 bit vista
2helpful
Need drivers for my VN960PC digital voice recorder for vista os
You will need to call Olympus to have those be emailed to you as they are not available for download from their website. Call their technical support line at 888-553-4448 option 5 and then option 2 for voice recorders.
1helpful
6answers
Olympus voice records
I bout the Olympus ws-21os that supports mac but it only supports wma so I had to buy easy wma that converts wma to aiff, wav,m4a or mp3 for $10.00
86helpful
11answers
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Unable to transfer folders from the recorder to the pc
I am using Digital Wave Player software together with VN-3100PC on Windows XP, it has a limiting functionality, but it works
Top Olympus Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Ngoro
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
