WHERE CAN WE FIND AN ENERGY SABER SWITCH IN THIS MODEL
Are you sure your refrigerator came with an energy saver switch? I can't find one listed for the model you have. If you are trying to add one, that is not something that is easily done for the older models. If my documentation is incorrect and your model did come with an energy saver switch or you are looking for another part, then you might be able to get it through www.searspartsdirect.com . Just plug in your model number and select model # search and you will get different models of your refrigerator. Select the one that applies and look for the correct part.
SOURCE: I have a Maytag rsw2700
Hi Ruben_J,
Is the compressor running? If it does and the machine is not blowing cold air inside the freezer you may have a leak inside the sealed system and all the Freon has escaped. If there's no Freon, no cool. You will need to call a repair man to have the Freon be fixed.
If the compressor is not running, in order for the machine to get cold, the motor has to run.If the condenser fan (fan by the compressor) is running and the compressor is not running then you have one of a few problems. Either the motor is not getting power and that's why its not running, or its getting power and the windings inside are shot and that's why it's not coming on.
Another thing that you can also check is the condenser coil. The Condenser Coils on your Refrigerator is where the Freon gets put under pressure, therefore causing them to get warm. In order for your Refrigerator to run efficiently these coils need to be able to dissipate the heat. If the coils are covered in Pet Hair or Dust, this will cause the sealed system to overheat. When the coils can't get rid of the heat created by the sealed system, the compressor will not be able to run.
Hope it helps.
Thank you for using Fixya.
SOURCE: We are trading in our
I don't think so ... if your refrigerator is qualified , it must bear a yellow sticker with red stars of your rating on the front side itself.
Kindly rate my answer if you are satisfied or not. Thanks a lot . Good day to you . Deepak Richard
