I was weed eating and my Ryobi gas weed eater made a pop noise and immediately stopped working. When I tried to start it the pull cord would pull and recoil but did not engage anything. would it cost more to fix it than it's worth?
Hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ~~ i need to know this before i can give you a answer,,
SOURCE: Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
SOURCE: weed eater won't start already Tried new plug
Did you check to see if the plug fires? If it shows a spark, check the air filter. Did you prime the carb? Does the fuel mixture mive smoothly through the plunger? If all that is okay, go through the carb. You might take a SMALL amount of fuel mix and put it into the spark plug hole, try to fire it. If it fires, probably your problem is the carb or fuel delivery to the carb....Good luck...Lee
SOURCE: weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The
next time you run the trimmer and it starts to die, loosen the gas
cap. If it starts running again, then you know that it's a clogged gas
cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
SOURCE: Weed Eater PE550 - How do you change the spring
Lay the unit on it's side, carborater down. Removed the 3 screws holding hold the gear assembly housing. Hold the clutch assembly inside a cloth with a wrench and remove the nut. Left from the starter cup as a stack and set aside. There is a starter retaining ring on the shaft. Pull this with a long nose plyers. If it spings free, it is easy to loose. Then left out the starter pully. The starter spring is under the pully. Remove it with a sharp pointed tool. A broken one is crusted in rust and will be snapped off inside the coil.
