Flashing lights I turned the fridge off and tried to turn it back on, the temperature control lights started flashing and the fridge will not turn back on.
When the panel lights on your Defy fridge freezer are flashing, it usually indicates an error or a specific condition that needs attention. Here are a few steps you can try to troubleshoot the issue:
Power Reset: Start by performing a power reset to see if it resolves the flashing lights issue. Turn off the fridge freezer at the main power supply or unplug it from the electrical outlet. Leave it unplugged for a few minutes, and then plug it back in or switch on the main power supply. Check if the lights continue to flash.
Check Error Codes: Consult the user manual or documentation for your Defy fridge freezer to identify the meaning of the flashing lights or any error codes displayed on the panel. The manual will provide specific information on what each flashing light or error code signifies and any recommended actions to resolve the issue.
Temperature Settings: Ensure that the temperature settings on the fridge and freezer compartments are set correctly. Incorrect temperature settings can sometimes trigger error codes or unusual behavior. Adjust the settings to the recommended levels and observe if the flashing lights persist.
Contact Customer Support: If the flashing lights persist or you are unable to identify the issue using the manual, it's recommended to contact the Defy customer support or an authorized service center. They can provide further guidance and assistance in diagnosing and resolving the problem.
The high temperature alarm or the red light indicator came on because the internal temp is high. This means that the temperature inside your appliance is still too warm. Keep your freezer/frig door closed and the light will go out in a few hours and you'll then be able to adjust temp or keep it as it was before defrosting.
My name is Peter. I am a retired field service refrigeration technician.
No. Your problem is not defrost.
The normal temperature setting for a freezer is -2 to +2 degrees F. or -18.8 to -16.7 degrees C. The fresh food section should be set at 35-40 Degrees F. or 1.6 to 4.4 degrees C.
Reset your temperature controls to the recommended settings.
Up plug your unit for 10 minute to power down. Plug your refrigerator in.
To Start the Appliance
Allow the appliance to stand for 2 hours after
installation. Plug in the appliance and switch on at the mains
supply. Turn the thermostat control (B) to a midway
setting and adjust the slider control, situated on the
back wall of the fridge section, to a midway position
between "MIN" and "MAX". The pilot light (A) will illuminate. Leave the appliance for approximately 4 hours for the correct temperature to be reached before placing food inside.
To switch off the appliance turn the thermostat
control to position "?"
After 4 hours, measure the temperature in the refrigerator and freezer. Should be between 2 and 10 degrees centigrade in refrigerator and app. -18 in freezer.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
