When I put CD in the unit keeps displaying no disc once i close the lid. Does anyone know how to sort this or what the fault is? thanks
Hello
Put it an other good known disc, which the set has played without any problem at all. If it also doesn read it, and displays no disc, the Laser Picku unit of your set has damaged. Put in a lens cleaning disc into the player, and play it for at least three times. If the fault is due to accumulation of dust or durt, the cleaning disc will clean it, and your set will be OK. If not repalce the Laser Picku Unit, sith same type and number.
The lens cleanig disc can be bought from most of the electronic sparpart selling shops at your town, and won't cost more. OK.
You can check on this:
How to fix a DVD "No disc" error (3 solutions)
If you can't solve this, you can also download a free Blu-ray player program which can be an alternative to it, such as Leawo Blu-ray Player
SOURCE: CD unit unit displays ''No Disc'' when there is a disc in slot 1
What does it do if you put 3 discs in and select each one? You don't say what it does with the other two trays. It would help to know that they work. If not, you have a bigger issue. Let me know.
