The radio checks to make sure the drive capstan is turning - if not, gives the E10 error. Either the drive belt in the radio is slipping or the drive wheel in the adapter is sticking. If it does it with a real cassette, then it's probably the drive belt. If not, you can try to figure out why the wheel in the adapter is not turning freely.
Chapter 6. Examine the tapes before inserting them into any drive or robotic environment to make sure the leader pin is present and properly clipped in (page 13).
Hi
Hope you come back for this
The 6A00 is a Canon generic code for paper path jam.
Solution 1: Move the printhead carriage back and forth a few times.
Solution 2: Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3: Press the ink pads down in the purge unit. Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
mode switch needs cleaned under tape unit on ckt board.. pain to get to. Put it together, pointing the same way when you took it apart looks like a round dot the size of a penny, with a shaft sticking up on the top twards the back
I had a similar problem with a Panasonic VCR. It would not eject the tape and gave an error code. I found that the door does not quite fully open, so that the top of the tape hits the door and cannot eject. If I turn off and then turn on the VCR the error code disappears. Then I press the eject button and simultaneously hold the door fully open with one finger until the tape starts to eject and clears the door.
this errror not related to psu section.After repairing this error occurs means its ncu or m.b. not properly packed, where machine last repaird send to that service centre check with this problem.
