How do you change the belt
SOURCE: Dirt Devil M084600 Dynamite
Your roller won't turn. The belt is designed to break if anything threatens to keep the motor from turning. When you have the roller out, check the end caps to see if they rotate easily. If they do, then install a new belt being very careful that the belt is not pinched on the channel that it sits in. Once you have the belt installed, turn the roller by hand to make sure that there is no jamming or catching of anything. Install the plate and check the rotation again. Once you are satisfied that the roller turns easily, try the machine.
If the caps on the roller are jammed, as they will get from debris, hair and thread, etc., then you may have to replace the roller. The end caps on most of the Dirt Devils are carbon fibre and will break when you try to remove them.
SOURCE: Instruction Manual needed for Dirt Devil upright model 088305
http://geeksquad.fixya.com/ThreadView.aspx?prdid=89362&thid=642772
Instruction Manual needed for Dirt Devil upright...
Posted by Innahouse on Jun 03, 2008
Describe your problem I need an instruction manual for a Dirt Devil upright model 088305.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Dirt Devil Model #M088300 Upright Vacuum. The best idea is to contact the Royal Customer Service Dept and give them the model 3 and serial 3 of the unit you are requesting the owner’s manual for, I will give you the website address and phone # listed below:
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
SOURCE: Dirt Devil Reaction Vacuum belt replacement
The manual is confusing - I had the same problem. Make sure you put the belt around the smaller motor axle, not the lever arm attached to the on/off foot switch. It's a bit counter-intuitive, but that was my problem with this. Jeff
SOURCE: where is the belt on the dirt devil vision turbo
the belt is to the left of the brush. You need to revome the plastic covering (4 screws) to see it.
SOURCE: How do I change the bag on a dirt devil model 103?
On the open end of the bag that slips onto the vacume, there is a cloth "tab" sticking up from the band. Take hold of this tab and lift up while easily pulling back until you see the band about half way off the vacume. Now, you can take hold of the band and pull the bag the rest of the way off. You will notice that there is a "rib" in the middle of the band on the side that faces the vacume. That rib fits into the groove where the band goes on the vacume. When you install the bag put the band on this groove and work the band on around the housing. You can center the "tab" anywhere, just place it where you can get to it easy. The other parts you need are on the internet, I found them all including that rubber plug called the "attachment port" plug. The p/n for the replacement part is 3-201744-601. The original p/n is 3-501744-601 but you'll be better looking for the replacement part number. Good luck!
