I removed the cover in the stroller to clean it and now i can't put it back on, there are no instructions in the manual on how to remove it or reassemble it. When i put back everything i can remember it seems to be stuck in a reclined position. can anyone help? also the pdf manual always freezes my browser online and will never finish loading.
SOURCE: Is this stroller compatible with other car seats such as Graco?
The manufacturer will not say that your Graco seat will fit in their stroller safely, however you could try your Graco in it and see if you feel safe that it will not fall out or be pulled out by your toddler.
Perego prefers to market their items to go with their car seats only, but we have found that the Graco seats fit nicely in most strollers. You should hook the stroller harness on to the lap belt routing path on your car seat to ensure safest travel in the stroller.
Good Luck! from Moms Just Know
SOURCE: Evenflo Journey Stroller seat recline question
To recline the seat on the Evenflo Journey Stroller, you have to pull up and back on the handle on the back of the seat.
SOURCE: how do I recline the seat in the graco quattro
there should be a lever at back of seat just lift and recline
SOURCE: adjusting seat in graco stroller
jacquelyn, you need to specify the model of your graco stroller.
SOURCE: Graco Stroller 7F00LPE3 removed
Good day!
I got the manual and this is for free:
you only have to do is click this direct link to access the manual.
click this====>http://www.gracobaby.com/customerservice/productinstructions/Pages/ByModel.aspx?page=ProdInst&Category=Strollers&Model=7F00LPE3
That is the official website of Graco.
NOTE:the manual are in adobe acrobat format but you can download it also to the link above.
Thank you and please don't forget to rate my answer.
i don't need to recline it i need to get it out of the reclined position the model is the alano #1750668 even when i follow the directions in the manual i could find it doesn't work its like now that ive removed the seat cover and reattatched it there is nothing to support the bar at the top of the seat.
