My tool does not have the access on the sides that you put a screwdriver and turn the housing to access the brushes. I can not find any information on how to remove the access pannels.
I figured it out. Use a small std slot screwdriver (not a jewelers or hobby screwdriver, more like the smallest standard screwdriver in your regular tool kit). My Type 2 Model 395 has a couple small tabs. Put the blade of the screwdriver on one of the tabs (shaft of screwdriver perpendicular to the tool) and press downward (not too hard) and toward you (if right handed). The plastic tabbed cover should rotate in towards the tool. That's the brush holder and you are rotating it 180 degrees so that the brush comes to the top. It will take a couple of "bites" of the screwdriver to rotate it fully. Be careful b/c the brush is under spring tension and if you rotate it w/o care it will shoot out (my first one did). Anyway, you should see a carbon brush with a slight arc cut in it if you have any brush left. Hopefully, you have little or no brush and a spring. Then it's easy to replace (my brushes were OK and just re-seating them and my tool was OK). Note that the 90930 brushes sold at most hardware stores won't fit. They are for the Types 3,4, and 5 model 395 (and other dremel models). You need the 90929 brushes for the Type 2. My camera is klutzy. If you can't get it, let me know and I'll try to post a picture or video.
SOURCE: Dremel 395 Type 2
Dremel Authorized Service Center
4631 East Sunny Dunes
Palm Springs, CA 92264
(800) 275-2052
Rob Dremel
they have the part you need for $1.25
SOURCE: obtaining a manual
dremel manuals are found here: http://www.dremel.com/en-us/CustomerService/ManualsAndLiterature/Pages/default.aspx
enjoy.
james
SOURCE: Dremel Model 395 Type 3 Plastic Drive Shaft
You can call Dremel direct at 1-800-437-3635 and order the part. Let me know if you need more information.
SOURCE: Dremel 395 rotary tool - not working
it is the coupling inside of it called a flex coupling and it seem s like it is made of wax or something. tomorrow i will go to home depot to see if they carry metal ones that won't break.
SOURCE: My Dremel tool motor still works but shaft won't turn?
From looking at manual there is no transmission or connector so the only possible explanation is that the shaft is broken. You might try calling this number
1-800-437-3635 to see if they repair or can further advise you.
Electrically speaking there are a few items to check.
1) The easiest is to remove the two brush holders screws on each side by the power cord. If one of the screws are loose, or the bushes are worn you will get intermittent or no operation.
2) Second use a volt ohm meter to make sure you have voltage on the two brush connectors inside the brush holders when power is on. If you do then open the unit a check continuity on the motor armature to see if it is open, which will cost $13.37. If you do not have voltage, inspect the power cord and switch.
Some parts can be purchased on the below link.
Or contact a dremel service center from the link below.
http://www.dremel.com/en-us/customerservice/ServiceAndRepair/Pages/default.aspx
