Bosch Axxis+ WFR 2460 Front Load Washer Logo
Posted on Oct 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bosch WFR 2460 washer - Drum does not move during wash/spin cycles
The drum does not move during the wash/spin cycles. No error messages appear on the display other than the usual wash program messages (like washing, spinning, fluffing). I have removed the back cover and the belt is on properly. When I select the spin cycle, it doesn't appear that the motor is even attempting to start. Thanks for any information you can give.
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Oct 16, 2008
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898659
Points
3964
Possibly the motor brushes.
take back panel off and motor is held in by bolts which undo - also disconnect electrical plug and socket.
check condition of brushes
Drum won't move
take the back panel off make sure power is off and check if the belt has come off or broken and also check the pulley that spins belt is tight and if all that is ok then it sounds like the motor might need to be looked at
2helpful
Bosch wfr2460
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
Bosch Axxis WFR 2460 Front Washer Drum/Cycles Not Working
hi sounds like the motor brushs are worn down,some bosch models you can change them without removing the motor ,but others its best to remove it,they just twist out,and to refit use a small blade flat blade screwdriver to tuck tab in,thanks
7helpful
Bosch wfk2801 washing machine drum does not rotate
Remove rear panel and check the belt is o/k, if it is, then remove belt, undo 2 bolts that hold motor, unplug the motor connector, lever motor back with a screwdriver, and remove motor.
Check the brushes, they should be at least 5mm long, \any shorter, then replace.
Plz rate my solution.
TRhanks.
Washing machine won't spin or rotate
Sounds like the motor brushes need replacing, you will have to remove the motor to do this.
Hope this helps.
Please leave feedback.
2answers
WFR 2460 Front loader
We went through the whole "clean the soap dispenser" deal and results were the same. Exploratory surgery revealed that the Prewash hose (for lack of better term), which connects from the top of the drum housing to the right side of the dispenser drawer (facing the machine)was completely clogged with gunk. Especially strange since we don't prewash hardly anything, ever. The hose that connects the bottom of the detergent dispenser with the side of the drum housing did have a lot of buildup, but I do not believe it was the cause because this was only happening on the rinse cycle. I also found the flow meter was frozen up.
2answers
Bosch WFR 2460 washing machine
the pum should do that but the magnet side may have saturated with water beyond the seal. i recommend replacing the pump.
Top Bosch Washing Machines Experts
NOEL
NOEL
Oliver Street
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
