There are several options to buy replacement batteries for a Coleman rechargeable lantern, model 5348-700. I just picked up two new batteries from www.1000bulbs.com for $4.87 each plus shipping. ($20.99 for 2 with shipping!) Do a Google search for: ub645f1 6 volt - 4.5 ah - f1 terminal battery for other options
Also if you are looking for a users manual, just email Coleman at: http://www.coleman.com. They will send it you in 2 or 3 days via eMail in pdf format.
SOURCE: lantern taken out of 5
I don't like to be the bearer of bad news, but it looks like there are no longer replacement batteries available for that lantern. Please see this link for repair parts from coleman. (also possibly here.) There is a customer service number listed at the bottom of that first page that will put you in touch with a Coleman representative, who may be able to suggest an alternative choice for your lantern. Failing that, the only solution I can recommend would be to take the lantern to one of the aftermarket battery suppliers (such as Batterys Plus, etc.) and see if they can provide you with a non OEM version of the battery you need for your lantern to take a charge.
Good luck. I hope you're able to find something.]
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
SOURCE: how to fit a mantel to a coleman propane lantern
Hi, First remove the knurl nut on the top. Remove the top and then the glass globe. There are several types of mantels most of which tie with a string that is part of the mantel top. The newer ones have a wire clip in place of the string. Which ever type you had on before you need to remove the old pieces completely. Since the mantles burn to an ash they will disintegrate when touched but if it had the metal clip you need to remove it. Tie or clip the new mantle over the lip on the output orifice being careful with the screen underneath. Replace the glass globe and top, put the nut back on finger tight. Remember that the mantel turns into ash when it burns for the first time so keep the gas low to start it till the mantle forms properly ( in the first minute) Good Luck, this should Fixya!
SOURCE: Coleman rechargeable lantern: Charged overnight -
Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
