SOURCE: Macbook Black
Hello yang2699tlk,
Try this instead of using your Leopard Disc.
This set of commands entered in "Single User Mode" will repair your disk. If this does not work remove the hard drive, plug it into another Mac and transfer your data to a different computer. Then install a new hard drive and reinstall Mac OS X.
Hope this helps, don't forget to vote. Thanks.
SOURCE: macbook Pro (now a Snow leopard) keyboard types q for a / ; for
Faulty keyboard due to dust or fluid spill. It needs keyboard replacement.
machinetosh of (tipidpc.com) site
look for kuya boy laptop
Global PC Laptop Proffesional Services
09126888500
SOURCE: New MacBook Pro, getting use to it, has Snow
Click the Apple menu (upper left corner). Click System Preferences. Click Mouse. Un-check "Zoom using scroll wheel while holding control." See if that fixes the problem. I assume you're using the mouse, not the trackpad. If you're using the trackpad, click Trackpad in System Preferences instead. Un-check "Pinch open and closed" under Two fingers.
Good luck. Let us know if this solves your problem.
* If you find this information helpful, please rate my solutions and recommend me. Thanks! *
Testimonial: "Thank You! Great feedback for the solution on this for me."
SOURCE: Need OSX Snow Leopard Driver for Laserjet 1018
This is the best solution for that problem and works perfectly...
http://blog.ragnarson.com/2010/01/mac-and-hp-laserjet-1018.html
SOURCE: Have a macbook (snow leopard)
Set the screen resolution to one which the projector can accept.
