It's hasn't been opening easly like before. I've had my Keurig Elite for almost 2 years now. With no problems. Now the top handle won't close. It's stuck open. Help please!
SOURCE: My Keurig just started only filling my mug 1/2
Have you tried following the descaling procedure given in your owner's manual? The mineral build-up from hard water can cause low flow, and since the machine pumps for a fixed time this means less water in the cup. Descaling usually brings back normal operation.
SOURCE: How to disassemble a Keurig B60?
As tgmusicgirl says you don't need to take the top off and you don't need to take the top silver part off to work on the insides. First take the bottom metal plate off as tgmusicgirl said then take the black outer sleeve off. The black outer sleeve is held to the top silver part with 3 plastic j-hooks which are part of the top silver part to hook into plastic brackets on the black outer sleeves. The j-hooks are located at the back about 1 inch from the left side, then about 5.25 inches from the left edge around the curve part of the sleeve and the 3rd hook point is in the front about 1 inch from the right front corner of the sleeve. There were no screws holding the sleeve as tgmusicgirl indicated on my B50 unit. Releasing the j-hooks without breaking them are very difficult since it's plastic and you can't see them to release them properly. Once the j-hooks are released the black sleeve slides toward the bottom to remove it. One way to imagine the j-hooks is to think that the j-hooks are pointing down with the open end facing the sleeve. The sleeve has rectangular rings molded on the inside of the sleeve and you just push the sliver part down into the sleeve until the j-hooks snaps into place.
I can't tell you that but I can point you to replacement parts dealer. The best of luck to you, Hope it helps:)
If you’re looking for Keurig Parts, you can find them on this website.
http://www.igotsweetdeals.com or http://stores.ebay.com/Igotsweetdeals
They have every Part for Keurig b30, b40, b60, b70, and b77. If it’s not listed currently and they can have it posted the same day! Even K-cup holder assemblies and water reservoirs!
SOURCE: Our Keurig is stuck. HELP. The LCD just says
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
SOURCE: My keurig won't even turn
The problem is often that the machine develops a leak in the hose that is rightover the transformer...the water drips onto the transformer and kills that...then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig OneCup Coffee Brewer will not turn on
heatman101
https://youtu.be/0Mg43v6vIkE
My 13 year old son and I fixed our 2.0 with two washers and some adhesive. Its a simple fix that you can easily do (even if you dont want to unscrew anything, but taking the cover off makes it easier. I really hope this video helps someone out there!! - Tim
