I have got Samsung Plano 29 inch tv. I see redgreen and white color lines at the top of the screen.this slides down till the middle of the screen. Please suggest
2 yr old 42 inch plasma.screen goes black,sometimes only half screen,sound is on.it does it after 1 hr of viewing, theres a greenish line in the middle of the black sreen when that happens,
pls help.
You have a burn in problem from watching widescreen movies.If you have access to a signal generator or tv setup disc run a perfectly white screen on the plasma for about 30 min.This should help even out the pixels on the display.
caution
whenever you see horizontal line please reduce brightness of your tv for safety of crt.
your problem in vertical section only mostly due to loose contact in
connector,print or loose components.
This is not a projection tv
