In Hurricane Ike, tv went off with light again. stayed off for about 2 minutes, when came back on television has a green screen with line running down sometimes, changes colors to blue, and purple. Sometimes looks likes picture will come in. The only way can watch tv is to use large pip which fill up half of the screen. Can anyone help?
SOURCE: Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
SOURCE: samsung hlr4266wx dlp tv shuts off
This tv usually if detects a fault will display via leds a error flash code. Refer to Owners manual for What the codes are for. If you go to Samsung Website Copy and paste link for manual.
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=televisions&group_cd=&type=televisions&type_cd=02010000&subtype=dlptv&subtype_cd=02010300&model_nm=HLR4266W&dType=D&vType=R&mType=&model_cd=&menu=download&prd_ia_cd=02010300&acc_ia_fl=N&disp_nm=HL-R4266W
Problem may be lamp is failing or ballast which operates lamp may be Bad. Could also be Temperature fault from Inoperable fan or Color wheel. Bulb of course is first choice of possible problem followed by color wheel then ballast. Color wheels usually will start making bearing noise when they start to fail. Hope this helps.
SOURCE: HLN507W Samsung 50" DLP
hello yes it sound's like your fly back transformer is going bad. to me.!!! just have to wait and see. wont take long if it's doing what you say. "hope this help's you "good luck"
SOURCE: I have a DLP Samsung HL-R6167w and it's not working
I had a bad digital board also. I went to parts.com to order a new part way cheaper than from repair service. the only problem I had was that after installation which is super easy 4 cables to unplug and replug. when I turned on the TV the picture came in upside down, not good. no one would give me the code to flip the screen as it is in a hidden menu, well after months of searching the web I found it!! It works for most all newer Samsung TV's. turn the TV off, hit mute then 182 and then power on button on the remote. the "hidden" menu will pop up and you scrool down to h-flip and flip the screen. I don't recommend messing with any of the other setting as you could likely really jack up the TV but at least you can fix it for a 3rd of the cost you would spend otherwise.
