The key wont turn at the final point to crank the car, last year my tumble broke, i had it fixed but when it broke i couldnt move the key at all, its not doing thay this time, 2 days ago i went to the...
Not an exact solution, but perhaps information that might lead to one.
1.Replaced the tumblers? I believe I would replace the entire ignition switch this time. It's my belief that the body of the ignition switch is worn inside, and will keep damaging the tumblers.
2.Do you have a tilt steering wheel? It's best to keep the steering column in straight line when starting the car, then tilt the wheel to where you want, after the car is started. When the steering column is in a tilted position, it puts undue strain on the ignition key switch, and the mechanism the ignition key switch operates, on GM vehicles.
This mechanism, consists of a half moon gear on the ignition key switch, that turns inside a 'Planetary' gear. I used the term 'Planetary', as the gear shape is hard to describe. It resembles an oblong loop, shaped like the number 9, with gear teeth on the inside bottom of the loop. This 'Loop' rotates, when the gear teeth of the ignition key switch, engage the teeth on the loop, and pushes a rod, or retracts the rod. The rod goes down the side of your steering column, and turns on, or turns off an ignition switch, located at the bottom left side of the steering column.
Having the steering wheel tilted, puts a strain on the ignition key switch internals, the oblong loop can break, and/or gear teeth can be stripped off.
van starts but cannot put in gear...speculation is that key was not properly inserted, forced into "on" position. That in turn caused our current dilemma. Suggestions? Comments? Do I need a new steering column?
