The camera's internal date/time "backup" battery is supposed to maintain the date/time for about 3 weeks with the camera turned off. If the camera is not used for a longer period, the date/time will need to be reset. If you are having to reset sooner than that, it is likely that the internal battery (not user replacable on most models) has failed.
To reset the camera, remove the battery for 15mins, then replace the battery and go to the camera's Menu and scroll to the Date & Time setting to set the current Date and Time.
yes its possible. Please remove the internal battery once and then put it inside after few minutes. This will reset the date time. while you switch it on once again. it will prompt you to enter new date and time.
Some of these cameras cannot save the date, and has no internal battery to save the data. The best solution I have use is to buy another battery with these kinds of cameras and always have one charging, or take two batteries when you take pictures. These older point and shoot cameras are nice, and slower than the newer ones, but will not save the data unless you keep the main battery in it, or replace the one to be charged with another battery within a very short time.
Try resetting your camera. In picture taking mode press menu. Go to setup, go up to reset, press right arrow, make sure reset is highlighted and press set.
Then TAKE OUT MEMORY CARD. Go back into menu, go to setup, go up to format, press right arrow and highlight format, press set. Input ur date and time again and then power off and back on. If that doesn't help then you have to send into repairs. 800-706-2534 and keep choosing option 2 and they will tell you where to send it.
Every time I use my camera after leaving it for 24hours I need to reset time date. Camera will not start until updated.
I have a similar but intermittent problem - sometimes when restarting the camera it starts up but with all the default settings - I have to reset the time and the user 1 and 2 settings etc.
I suspect that like many other cameras there is an internal battery that needs to be replaced after a couple of years - I'm going to bring it to a local repair place and have them run a diagnostic. If I get and answer I'll let you know.
If anyone else has a possible solution let us know .
Thanx
The camera can be set to retain all your camera settings each time the camera is turned off and on. Press the OK/MENU button. Then press the right arrow to access the Mode Menu. Press the down arrow to highlight the SETUP menu. Press the right arrow to highlight ALL RESET, and then press the right arrow again to highlight ON. Press the OK/MENU to save this setting and return to the Mode Menu. The camera will now retain any settings such as Quality each time you turn off the camera.
The D-390 allows you to choose if you want the camera to retain your settings or to default the settings. In the camera menu, there is a function called “All Reset”. If the selection is ON, the camera will default all settings each time the camera is powered on/off. If the selection is set to OFF, the camera will remember all of the settings that have been made.
This is the first time you turned on the camera, or the battery has been removed for an extended period of time, or the battery is exhausted. Reset the clock.
