Genius BT-03A Bluetooth Headset Logo
Sakvi Posted on Jan 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Not able to pair my bt-03a with my android device
I am not able to pair this device with my Motorola defy. It says pairing rejected or communication cannot be established.
CARLOS R SOUZA JR
Level 3:
President:
  • Master 1,118 Answers
  • Posted on Feb 14, 2012
CARLOS R SOUZA JR
Master
Level 3:
President:
Answers
1118
Questions
0
Helped
305265
Points
3552
Have you already tried to put your headset in pairing (discoverable) mode first? Anyway, in order to do it, starting with it turned off, press and hold the 'Play' button for some 7 seconds, until the indicator light is alternately lit in blue and red. It is in pairing mode now. Then, withing a couple of minutes, on your phone, go to 'Menu > Settings > Wireless & network > Bluetooth'. If the bluetooth radio is not turned on, turn it on. Then, tap 'Scan for devices'. After a little while, your headset should appear on the phone' screen. Tap over it to make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is succesful, your headset should enter the stand-by mode. An indication that a heaset is connected should appear on your phone too. If your phone indicates that only phone calls are available, tap and hold over it, until a context menu comes up, and select 'media', in order to make streamed music ffrom your phone sound on the headset.
Hope it works for you.
Anyway, please, let me know if you need further informations.
Regards,Carlos
Bluetooth pairing
Both devices' B.T. = on.
Device A = "Search for devices"
A finds B...
Select Device B to pair with.
On B accept pairing with device A.
May ask for BT passwords, try 0000 as default.
I can BT pair to iphone,but android phone pairs, but I get no audio
go to BT device listing then tap device and setup wheel check on call audio and media audio.
How do I pair motorola h700 with motorola defy?
Enable Bluetooth on your Defy. Then follow these instructions H700 Different Paring Instructions then search for H700 on your Defy.
Mark
Motorola Support
How do I set pairing mode
You will need to be sure that your device has BLUETOOTH. If it has bluetooth please turn on the bluetooth settings on your android device. You will now want to turn on the speaker.
Using the android device you will search for available bluetooth devices. Once you see BT-100 you will select that to PAIR. Some devices will automatically CONNECT after the devices have been paired. If not, please press BT-100 again to CONNECT. The BT-100 speaker should BEEP indicating that they have connected and the speaker is now ready to use.
If you continue to have trouble feel free to contact the manufacturer at [email protected] or going to http://www.contelusa.net
Bluetooth is paired. Works for about 1 day. Then will not connect again.
Did you try the "Device Discoverable in ___ secs?".In settings, Make device discoverable first then set the length of time. Android phone have this limited BT capability i think.
Discover Bluetooth Device Not Available
uninstalled the rom
bad idea that.! why mess with ROM. ouch.
test the PC on other BT devices, if it works then the PC is good.
even a BT head set, mouse, or any other vast numbers of BT devices, (not apple sure)
Driver for bluetooth headset Genius BT-03A
go to add hardware option and search your device and when it says to install the software select the option to install it automatically and then you will be asked for an internet connection and the software will be installed automatically
I cannot pair my nokia e63 with genius bt-03i. seems the phone can't sense the signal from the headset or either the headset is not transmitting bluetooth signal
Make sure the blue-tooth headset is charged
Make sure the phone is set to automatically detect new blue-tooth device.
On the headset, press the power key for five seconds until the RED light blinks quickly.
Phone should detect headset within 10 - 30 seconds. It should eventually say BT-03A then ask for aOnce it does, type 0000 into the phone when it asked for a device ID.
Trying to pair my phone with my hp mini through bluetooth it wants my security code for my mb525 motorola defy
When pairing a computer with a cellular phone, you can set your own 4 digits passkey, which must be entered at both devices upon request.
In the following link you can download the user guide:
http://www.motorola.com/staticfiles/Consumers/Products/Mobile%20Phones/MOTOROLA-DEFY/_Documents/_Staticfiles/DEFY_UG_SA_EN_68014561001.pdf
Feb 20, 2011 • Cell Phones
Motorola H700C Pairing with LG VX8700
im having a problem with my h700c and my lg too it was paired with a samsung and i got the lg now the phone phone the BT fine it just wont pair,wat can it be?
Top Genius Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Genius Radio Communication Expert? Answer questions, earn points and help others
