Empty coolant tank. Don't run it until the coolant level is checked and at the correct level. If this doesn't fix it you could have a failed coolant pump.
see the causes and remedies: It spins, but doesn't pump drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace It doesn't spin or pump frozen pulley pump, replace It pumps, but the water returns
improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly. God bless you
Drum will not turn or rotate
1.broken or slipping belt---replace belt
2.jammed or bearings frozen ----check for foreign article between drum & shroud
Replace defective bearing or bearing support which allows drum to sag or hit
3.loose pulley----tighten pulley set screw
try some wd 40, spray it on the area of the take up lever & let it set for at least 10 minutes then with the hand wheel on the right hand side slowly move the hand wheel toward you & if it still doesn't move re spray again & wait again then try the hand wheel again to move toward you eventually it should start to break loose if it's just stuck.
since you pruchased it at a estate sale, there not much telling when the machine was serviced last
if the spraying doesn't work, consider having it serviced
Water pump. The impeller will slip on the shaft. As you said runs fine at idle, but when you run it harder the impeller doesn't spin fast enough (slips). Causing it to over heat. replaced to many for this problem. Also The pumps that have the metal impellers will be tight when cold, don't let this fool you. when they heat up they slip.
New transmissions --- are only new once
When installed on the assy line
Has to be rebuilt if necessary
PO 147 ---O2 Sensor Heater (Bank 1 Sensor 3) don't have one of those
PO714 -- Trans Temp Sensor -heat for the slipping
PO 471 --- Exhaust Pressure Sensor -don't have that either
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
