I was instrol androlock in my phn. after few day i turn off my phn nd start it. its take many time nd when start i slid nd unlock.bt home screen didn com.lock screen stil display.then click on menu. lock seting come. i can use notification bar from here. call come nd i can call any one. i can't go phn menu. i think if i uninstrol lock soft it will be ok. bt i can't go setting even any were.what i have to do? flash?
SOURCE: black screen,no picture just a sound.not even menu bar displays
I had this same issue a year ago and I have it again. I was told it is the light. The company sent me a new one I installed it easily. Worked fine I am not sure why mine died so fast
SOURCE: Samsung SCH-u740 problem - front screen stays on and speakerphone switches automatically
it seems like the inside screen stays on as well. Does the phone know its closed?
SOURCE: screen menu displays locked & unlocked
Hold down the menu button for 5 seconds (with the monitor turned on). It should reset the lock option.
SOURCE: My LG venus phone keeps flashing between locked and unlocked!
hi im josh in cebu phils. may i help you? Friend the problem of you phone is the software it may be corrupted. You need to reflash the phone software. Go to the service center and let tell your problem and they will perform the job. Good luck hope i helped you.
SOURCE: Will not start; Several interior lights also flash
It is your battery. I just had this happen to me, had the battery checked and replaced.
