This cable is for both the power and voice signal to the Soundstation, which is the pin-outs for power?This cable is for both the power and voice signal to the Soundstation, which is the pin-outs for power?
STANDARD SOURCE LOAD REMARKS Ethernet RJ-45 connector pin number Source Voltage 1 2 3 4 5 6 7 8 Load Voltage DC Load Connector IEEE 802.3af using data pairs 48 V DC, protected RX, DC+ RX, DC+ TX, DC- spare spare TX, DC- spare spare (embedded) Industry Standard for active PoE IEEE 802.3af using spare pairs 48 V DC, protected RX RX TX DC+ DC+ TX DC- DC- (embedded) Industry Standard for passive PoE Intel, Symbol, Orinoco Usually 12 or 24 V DC RX RX TX DC+ DC+ TX DC- DC- (embedded) Most Brands of PoE Cisco (OLD old standard) 48 V DC RX RX TX DC- DC- TX DC+ DC+ (embedded) Older Cisco polarity is REVERSED Cisco (NEW old standard) 48 V DC RX RX TX DC+ DC+ TX DC- DC- (embedded) New Cisco is IEEE compliant Cisco (very unusual)
28 V DC DC+ DC- TX n.c. n.c. TX RX RX (embedded) Seen on Cisco 7936 conference station D-Link (Adapter) 48 V DC RX RX TX DC+ DC+ TX DC- DC- [email protected] or 12VDC@1A
DC coaxial 5.5/2.5mm D-Link PoE Adapter for non-PoE products. Apple MacIntosh AirPort PoE, Extreme 48 V DC RX RX TX DC?? DC?? TX DC?? DC?? Converted to ??? DC coaxial (???) Mac Polarity Unknown HyperLink Many DC Voltages Available RX RX TX DC+ DC+ TX DC- DC- same as input DC coaxial and others available Variety of Options Available to Fit Most Brands of PoE NYC Wireless Roll Your Own 12 or 24 or 48 V DC RX RX TX DC+ DC+ TX DC- DC- same as input DC coaxial or as reqd New York City Wireless PoE 3Com AirConnect 24 V DC RX RX TX spare spare TX DC+ DC- 3Com AirConnect wireless access points Alvarion VL 55 Vdc RX RX TX DC+ DC- TX DC+ DC-STANDARD SOURCE LOAD REMARKS
IEEE 802.3af
IEEE 802.3af
Cisco
REVERSED
Cisco
[email protected]
or 12VDC@1A
DC coaxial
NYC Wireless
Well i tried to draw it, but it didn't come out that great. LOL. The pins are numbered from left to right, as you are holding the connector in your hand like you are going to insert it into the female receptacle, with the tab pointing down. Typically numbers 4 and 5 are positive, and numbers 7 and 8 are negative.
Like I said, this is typically how they are!!!!!! I cannot make any guarantee that your equipment is set-up this way. PROCEED WITH CAUTION!!!!!!!!!Well i tried to draw it, but it didn't come out that great. LOL. The pins are numbered from left to right, as you are holding the connector in your hand like you are going to insert it into the female receptacle, with the tab pointing down. Typically numbers 4 and 5 are positive, and numbers 7 and 8 are negative.
You can't post conmments that contain an email address.
Hello Edward, This is a known issue with this product that requires a software upgrade
to resolve. Please download "SoundStation2W Software Upgrade" from the Product Support page
of our website and follow the included instructions. If you need any
assistance please don't hesitate to call for assistance at
1-888-248-4143 Options 2, 4.
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
You need a meter to test the voltage else check the manual or normally it is written on the transformer about power,voltage and current.Hope this helps.
The SoundStation Premier and Soundstation Premier EX has been discontinued and is no longer available for purchase. Support for the product will be available until 02/21/2010.
My Polycom sound station power unit malfunction. I found that AC transformer broke.
If I try to get substitute transformer, what is the required ac output
(Vac) and Amp that I need to find?
IEEE 802.3af
IEEE 802.3af
Cisco
REVERSED
Cisco
[email protected]
or 12VDC@1A
DC coaxial
NYC Wireless
12345678
_________
|________|
