Keyur Patel Posted on Jan 20, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2 sided booklet option - Ricoh Office Equipment & Supplies
Anonymous
Level 3:
  • Ricoh Master 32,281 Answers
  • Posted on Jan 20, 2012
Anonymous
Ricoh Master
Level 3:
Answers
32281
Questions
Helped
7912385
Points
102259
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
How to print 11X17 Booklet on CS Kyocera CS3011ikx
Kyocera printers are well-known for their efficiency to produce brilliant color prints. The printer can deliver high-resolution output with crisp black and white text and graphics. The CS Kyocera CS3011ikx printer can print multiple copies that can be folded into a single booklet. Printing a booklet can minimize cost. Read through the instructions given below to understand how to print a 11X17 booklet on CS Kyocera CS3011ikx printer.
1 Press the Copy menu on the control panel to initiate the process. Select the Layout Edit tab.
2 Click the Booklet option.
3 The printer supports single-sided and double-sided printing. Choose either of them according to the printing requirement.
4 Change Default settings and mention the size of the media.
5 Place the original document or text in the document feeder.
6 Press the Start button.
7 Select the appropriate print size. Modify the size as 11X17 to meet the booklet requirement.
8 Change the page size.
9 Open the PDF document.
10 Select the options File> Print. Choose your printer from the list displayed on the screen.
11 Cut and staple the edges of your booklet. Trim the ends of the pages if it is necessary. Call our Toll-Free 1-866-293-9220
4answers
Booklet layout
Is page on printing on the left hand side or right hand side?
<a href="http://stashbox.org/77137/printing.png">http://stashbox.org/77137/printing.png</a>
<img src="http://stashbox.org/77137/printing.png">
HP P2015dn when printing booklet, double side print, the print on the back of all pages are upside down. How do I fix it
Many duplex printers have an automatic setting for booklet print. If not, you have an option in the printer settings for long side or short side flip. If you are printing an A5 booklet (ie A4 folded) the setting should be landscape, two pages per sheet, flipped short side.
How to copy a booklet on the canon 3045
To make a stapled or folded booklet on the 3045 will require the "Saddle Finisher option. This is a finisher the attaches to the left side of the copier. It has 2 trays and an additional tray on the very bottom of the finisher. If you do not have this it will be impossible to make a booklet that is two sided with the pages properly sequenced. If you have the saddle finisher attached. On the screen select special features and on the first or second screen you will see a booklet button, press that and follow the prompts. If the booklet button is greyed out you do not have the Saddle Finisher.
Operating buttons on wenger watch
Go to the Wenger web site (wenger.com).
Select "watches"
At the bottom of the page there are a number of tabs, select "services".
On the right hand side of the screen are two options below the search box, select "booklets"
Opposite "instruction's booklet" there is a small red tab, select this and the instruction booklet for all Wenger watches will appear.
Jan 05, 2010 • Watches
Printing booklets without reducing contents
Click on the "arrange" tab and then click on Layout Guides, and the margin guides will come up. 1" is trhe default setting, you can set it to whatever you want
2helpful
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
I need to make a booklet. so when i print the document it be read like in abook
Hi, I dont actually use PageMaker, so you might need to check your help file for more info.
Basically you need to look for an option that lets you 'impose' your document (there may be a tool box or print option for imposition).
If you cant find it just do the imposition yourself.
For a simple 8 page A5 booklet you would want two A5 pages side-by-side on an A4 sheet of paper.
Back cover would be on the left (pg8) - Front on the right (pg1).
Inside front cover on the left (pg2) - inside back on the right (pg7).
Then the centre pages - right (pg3) - left (pg6)
Inner double pages - left (pg4) - right (pg5)
Hope that helps!
arceye10
2helpful
2answers
Printing a Booklet on a Ricoh Africio 3260C
first you need to use the RPCS printer driver supplied by ricoh. Second then go to printer properties box and then select the tab for finishing, you should then see the options for booklet printing, if the option are not there you have to add the finisher in the printer driver as an option
http://www.websitetoolbox.com/mb/copierquestions
Printing a booklet on WorkCentre 7345 , need help argent !!!
OK, same problem, I've gotten through the solution. I can print and have the first page and last page on one side of the large sheet and the two inside pages on the other side, so that is foldable into a booklet.
I start with a 4 page (US letter sized) document I wish to print as a booklet on tabloid paper.
In the (page layout or editing program's) print dialogue, I've said print all pages, set it at 1 page per sheet, then clicked the printer properties button to open the Xerox Workcenter 7345PS option dialogue.
In the Xerox dialog on the "Paper/Output" tab, selected the larger (Tabloid, 11x17" in my case) paper size, selected 2-Sided Print. Then I select the "Layout/Watermark" tab and clicked the Booklet Layout radio button, chose "Landscape" for the Page Layout Option. Note: I saved these settings as "Tabloid Booklet" by clicking the down-arrow to the right of "Driver Defaults" so that I could select them and not have to dial in every one of the settings whilst experimenting.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
