Question about Home
Replace shower door - Home
  • 3,917 Answers
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Posted on Jan 20, 2012
Testimonial: "Thank you"
SOURCE:
Where can i find parts for my shower door
Go to nearest home depot. They can help yo.
Oct 12, 2015 | Home
Make image modle BS 6206 door roller need replacing
We don't have parts here. Check the manufacturer's website, Amazon, eBay, and Alibaba.
May 12, 2015 | Home
Replace hollow gasket vista-pivot ii shower door
Usually the bottom of most framed doors has a chanel which contain door sweep or hollow gasket,all you have to do is pull it and slide the new one in the same place.
Please note that some times the end of the chanel is crimped to prevent the gasket to move in and out of the track.
I hope this will help.
Nov 30, 2013 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Glass Shower Door
If you don't plan replacing the shower door, fill the holes with tile colour grout or other fillers you can buy from hardware stores. I am saying grout because if you have coloured tiles, the filled holes won't show prominently, otherwise fillers are ok.
Jul 10, 2013 | Home
Sliding shower doors the cord that moves doors need to be replaced
Shower Door cord replacement routing.
Lace cord as shown, leave a bit of slack in the cord before knotting the end. sliding-shower-doors-cord-moves-doors-4aupsgfnj4xszkulrofnusgv-4-0_0.jpeg
Jul 16, 2012 | Plumbing
My partner didn't have any idea of fixing a shower door so it can close properly so what he has done is grinded the metal part of the shower frame so the door does not hit it when it close. Now because he...
Hello, W/D here.
You can file and sand the burrs smooth and eliminate the hazard somewhat or you can probably buy a replacement threshold from a local shower builder (really, they're out there). Look in the book for custom shower/bath builders, and they'll have parts. The hardware stores rarely have shower thresholds, but you could look; you may get lucky. Usually, they would rather sell you a kit. We had a replacement shower door built with side panels, and it was pretty easy. If you want a replacement door frame, you can call it that, and they'll know what you mean. If you ask, they'll probably come out and take a look for free, and estimate the cost for them to do it. When we were going to replace our shower door and panels, the cost of them doing it vs. me getting the proper parts and doing it myself were so close that we just let them do it. Sometimes it just works out that way. They measured, built and installed it in several days. Your "repairs" will take much less time.
Best regards, --W/D--
Mar 08, 2011 | Home
Where can I find shower door rollers for a maax shower door? Thanks.
amazon is one of the best places for purchasing your shower door rollers. Click here Amazon com shower door rollers and choose the best one (many of them are compatible with maax shower door), but anyway, before order something contact the seller to be sure. There's a plenty of rollers, so take a look.
I hope this was helpful.
enjoy
Mar 05, 2011 | Home
Have a sterling 1500D-42S shower door. Need to
sterling is an inexpensive kohler product,....go to a plumbing supply store with your #s and they'll be able to get what you need.
Jan 02, 2010 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Home Logo
365 people viewed this question
Top Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Home Expert? Answer questions, earn points and help others
