Question about Hotpoint WMA13 Front Load Washer
Hotpoint WMA13 door lock fault
Hotpoint wma13 with door lock fault fitted new interlock fault on display stillpresent door wnt lock and machine wnt start
  • Anonymous Mar 22, 2014
    not draining water
  • Hotpoint Master
  • 3,463 Answers
If the door locked light is flashing , then the main board probably has a fault on it, due to a problem with the motor, or the board itself being faulty.
Recommend calling an engineer.
Posted on Jan 04, 2009
SOURCE:
My washing machine drum wont turn. The washing machine fills with water then just sits with water in it. It will drain but wont spin It worked fine yesterday, but today nothing. When I turn the drum by...
hello. if it don't turn then it could be the brushes on the motor also check the interlock on the door. any spin problems could be the module control board get back to me if you still have problems
regards
shaun
Jan 03, 2011 | Hotpoint WMA13 Front Load Washer
How to replace bushes on hotpoint wma13
I assume you mean the Brushes in the motor..Remiove lower rear panel of washer.
Unplug lead to motor. Remove earth lead from motor.
Remove belt, and undo 2 screws securing motor to bottom of drum.
Lever motor away from you, and remove motor. and locate brushes at the opposite end to the pulley
Hope this helps you.
Dec 07, 2009 | Hotpoint WMA13 Front Load Washer
Hotpoint wma13 wont empty, think pump is blocked
Yes,
The water pump most be clugged and/or defective.
Aug 18, 2009 | Washing Machines
Washer stopped dead in the middle of cycle
CHECK ALSO the sensor switch underneath where the door close , you gonna need a tester for this task ,hope this helps AJ
May 05, 2008 | Hotpoint WMA13 Front Load Washer
Fitting new module
just switch off the machine and re start the programming procedure again did you get the programme sheet with the module
Jun 13, 2007 | Hotpoint WMA13 Front Load Washer
Hotpoint WMA13 Front Load Washer Logo
368 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
